russbost
posted on 26/7/10 at 11:04 AM |
Printer suggestions please?
Hi all, currently using an Epson D92 printer for all my personal & business printing, it's started playing up a bit so need to get a
replacement b4 it expires! I would welcome any input/feedback re current printers - I want something with a reasonable speed (the D92 is a little
slow), must be capable of doing colour & an occasional half decent colour photo - main thing is that consumables must be CHEAP as it does a lot of
work hence don't want something using bespoke cartridges at half the national debt each! I currently pay about £1.50ea for cartridges & get
thro' one or more colours every 2 - 3 weeks.
Any suggestions for worthwhile purchase or indeed an "avoid at all costs"! Running costs much more important than initial purchase
price.
Ta!
posted on 26/7/10 at 11:14 AM |
I have a HP printer that I'm well pleased with - but consumables can be expensive.
You might like to look at the latest range of Kodak printers, as they claim to have very low consumables cost.
posted on 26/7/10 at 11:21 AM |
apparently the manufacturers loose money selling the printers, but it is more than recouped selling the ink cartridges (aka black heroin).
I have a wireless EPSON but cannot recommend it simply as I have not used it enough - do most of my printing at work
se7en
posted on 26/7/10 at 11:39 AM |
I use a Canon PIXMA IP4600 and it gives excellent results. See here
>Canon IP4600
Cartridges can be easily refilled; new ones are not too expensive (cheaper than Epson or HP). I buy the ink and refill when needed.
Has two paper trays and the facility to print on CDs although I have not used this facility yet.
HTH
Tom
ReMan
posted on 26/7/10 at 12:11 PM |
>Canon IP4600
HTH
Tom
They are a fantastic printer
If you are hammering one though it is probably time you moved up to a colour laser.
Something like this
http://www.canon.co.uk/For_Home/Product_Finder/Printers/Laser/i-SENSYS_LBP7200Cdn/index.aspx
MikeFellows
posted on 26/7/10 at 12:58 PM |
by the sounds of it, its time to move to a colour laser.
however it wont do photos very well (unless your spending big money)
you can pick some reasonable colour lasers for around £200
toner will cost you more in consumables but depending on the printer it will last a lot lot longer (think 1000's of prints per cart)
expect to pay around £50 PER toner cart compared to £20 for inkjet but they will last a lot longer and they are always faster than inkjets.
a4gom
posted on 26/7/10 at 01:20 PM |
Not sure if it will tick your boxes but it did mine, I don't print that often and was sick of cleaning heads/ changing cartridges everytime I
wanted to print a sheet so I opted for one of these, touch wood it's been great so
far, unfortunately now the wife and kids know it works ok everytime and it's networked we are printing a lot more than before.
Perfect planning prevents pi$$ poor performance!
posted on 26/7/10 at 01:46 PM |
HP printers never give any problems until they wear out, downside is cost of cartridges.
Check out carefully life of XL type cartridges v cost for each model before buying.
russbost
posted on 26/7/10 at 02:45 PM |
Thanx for the info guys - will now go & continue scratching my head! Might go for the Canon, don't really want a laser unless absolutely
necessary
se7en
posted on 26/7/10 at 02:58 PM |
necessary
I bought the Canon IP4600 because I did not think the quality was there in the HP7762 that I have. I was doing my daughters wedding stationery; turned
out a treat.
Go to one of the stores selling the Canon and others and ask them to demonstrate them for you and then make up your mind.
[Edited on 26/7/10 by se7en]
PSpirine
posted on 26/7/10 at 05:33 PM |
My HP 5900 (just a basic printer, no frills) has been infallible, and prints quite well too! Check ink prices though (I buy refilled cartridges and
they weren't too bad) because some printers (DELL!) are impossible to get cheap inks for and don't like being refilled.
Only thing I don't like about HP is that HP inks are water soluble, so if you get your beautiful prints moist or get a drop of water on them, it
runs.
Epson inks are acrylic I believe and once dry don't dissolve the same way. Not sure bout other manufacturers. I've got an Epson SX200 now
networked through an Apple Airport and it's fine, but it's certainly no better than my bog standard HP, and the driver suite for it seems
to take up my whole hard drive!
