New Topic New Reply
Author: Subject: Screenwash bottle problems
posted on 27/7/10 at 08:05 AM Reply With Quote
My windscreen has been fitted for a while now, but not the screenwash. My next MOT is in mid-October, so it needs to be sorted - but - I have very little space to fit the tank.
There are 2 tanks easily available on ebay - both have the regulation 1.2 litre capacity, neither will fit in the available space. I don't need to worry about IVA, but I do need to be able to provide a few good squirts for the MOT tester.
I've also tried a reproduction bottle for a classic Mini, but its shape makes it impossible to fit.
Other than making a tank (last resort), can anyone think of a production car that has a small water bottle that could be pressed into service. With or without a pump - I don't care. It can be 6"or so in length, 4" or 5" high, but only 2" max thick. Ideally it would have a bottom water outlet, but I can adapt an otherwise suitable bottle.
MakeEverything
posted on 27/7/10 at 08:08 AM Reply With Quote
Get the bladder type. I had one in the dutton, and it was like a colostomy bag hanging high in the passenger footwell.
Worked well, with a manual press button to squirt the water.
Kindest Regards,
Richard.
RickRick
posted on 27/7/10 at 08:10 AM Reply With Quote
bmw concentrate bottle might do the job, E39 ones got to be somewere near your size limit (from memory)
posted on 27/7/10 at 08:25 AM Reply With Quote
6x5x2 = 980 cc.
these are narrow but weird shape:
volvo 850
[Edited on 27/7/10 by 02GF74]
jabbahutt
posted on 27/7/10 at 10:33 AM Reply With Quote
Car builder solutions do the bladder type washer bottle kit if that helps. That way you more options of where to fit it.
posted on 27/7/10 at 10:36 AM Reply With Quote
Can't you fit two small ones and connect them via a t-piece?
posted on 27/7/10 at 12:16 PM Reply With Quote
You can fit the pump and tank anywhere ie in the back of the car.
posted on 27/7/10 at 12:38 PM Reply With Quote
Good thoughts from eveyone!
Colostomy bag - a bit long to fit under the bonnet.
Don't really want anything in the passenger compartment.
In the back of the car - good idea, although I currently have a fitted boot box that I'd be reluctant to hack around. The boot box is also quite easy to remove if I need to do maintenance, which I'd be reluctant to lose. I wouldn't want to lose any capacity either - there's not much space in there!
How close to the exhaust manifold can I put a water bottle? The colostomy bag might be a risk if I jammed the brakes on (it would probably swing into the pipes), but I might be able to squeeze something rigid in there (oooer, missus!).
posted on 27/7/10 at 06:45 PM Reply With Quote
Got mine under the rear cover with a flexi filler neck
New Topic New Reply
