New Topic New Reply
Author: Subject: flexi hose and speedo cable mounting
smart51
posted on 4/8/10 at 12:17 PM Reply With Quote
My single seater build is coming on and I've fitted the front flexi hoses and the speedo cable which is driven off one of the front wheels. Being a single seater, there is a fair gap between the wheel and the bodywork. Will the MSVA inspector want to see the hoses and cable supported in the middle or will supports on the chassis alone be adequate? I could weld a tag onto the under side of the upper wishbone to hang them off if needed. There's about 400 or 500mm of unsupported hose as it stands.
Edit to say in the straight ahead position there is 340mm between the last support and the connector on the master cylinder, which doesn't seem so bad.
[Edited on 4-8-2010 by smart51]
Humbug
posted on 4/8/10 at 05:27 PM Reply With Quote
Not sure what the inspector would say, but 40-50cm unsupported sounds like a bit too much to me. I would add the tabs, as long as it still gives enough bending room for the cables/flexis
New Topic New Reply
