posted on 2/10/10 at 04:15 PM |
What Dia Rivets Do (Did) You Use?
I'm replacing a couple of the more tatty ali panels on the car and slightly concerned about the rivet size used by the builder.
The spacing is pretty much normal, but is a 5mm drill hole not a bit excessive? What are these big holes doing to the strength of the chassis rails?
It's Evolution Baby!
flak monkey
posted on 2/10/10 at 04:22 PM |
I used 4mm sealed end rivets for everything....
Sera
http://www.motosera.com
RichardK
posted on 2/10/10 at 04:24 PM |
Sure I used a 3.2mm drill for my 3mm rivets ifs that of help, I used them all over without any probs 3 years down the line.
Rich
Gallery updated 11/01/2011
posted on 2/10/10 at 05:04 PM |
Ø4.0mm closed end rivets all over including the floor (Ø4.2mm drill).
posted on 2/10/10 at 05:21 PM |
Thanks guys... would appear that my chassis has lost a fair bit more of its metal than it need have done!
Worth welding up the holes and re-panelling, or just bung more 5mm rivets in and be done with it!??
clairetoo
posted on 2/10/10 at 05:24 PM |
Mine all done with 5mm rivets and hasnt fallen in half............yet
Its cuz I is blond , innit
Claire xx
Will weld for food......
RazMan
posted on 2/10/10 at 05:26 PM |
Welding up the holes won't do any favours for chassis strength - I would just use 5mm rivets and leave it at that.
p.s. I used them in my floor panels - 3mm everywhere else.
Raz
posted on 2/10/10 at 05:32 PM |
Hurrah... my glass is now half-full
Cheers folks!
bonzoronnie
posted on 2/10/10 at 05:34 PM |
I used 4mm rivets on the panels I have done so far.
I have often thought of this hole malarky, surely if the hole is being filled with a rivet or the likes, the full strength of the tube will remain (
More or less ) !!??
Of course this assumes the said tube is never going to have a sustantial force applied to the opposite side of the tube ![](/images//smilies/smile.gif)
posted on 2/10/10 at 07:26 PM |
Certainly I wouldn't entertain welding the hole up Scott - IMO you'd do more harm than good and give yourself issues when re-drilling for
the next set of rivets.
Repanel with Ø5mm rivets and leave at that.
posted on 2/10/10 at 07:28 PM |
Cheers Nick!
Thanks for the advice all... 5mm rivets are going back in!
Theshed
posted on 2/10/10 at 07:34 PM |
The Hi-cost solution is to use structural locked stem rivets. 6/32" would probably fill the holes. Are you really worried? If so I may have some
of these in the depths of my shed - special tools to fit even deeper....
posted on 2/10/10 at 07:37 PM |
Oooh... interesting development!
procomp
posted on 3/10/10 at 02:39 PM |
Hi
You sure they are 5mm rivets. The kit was suplied with Tucker 4mm sealed rivets. ?
Of course theres no saying the original cutomer used them
Cheers Matt
