smart51
posted on 15/10/10 at 05:59 PM |
Light switch symbols
I'm using a fiat cinquecento steering column and now I'm doing the wiring, I realise the headlight switch only goes between dipped and
main beam (with flash). On the other side, there is a wiper switch with 2 speeds. I'm thinking of using this for off-side-headlights. I can
remove the wiper symbol easy enough but then I'm left with no symbol. I don't mind but will the MSVA inspector object? Can you get stick
on headlight symbols?
davrus
posted on 15/10/10 at 06:19 PM |
Hi ya
Yes i beleive you will need them to be labbeled.
I am planing on using these Dash, Switch, Symbol Sticker Sheet, Rally, Kit Car, on eBay (end time 12-Oct-10 10:48:43
BST)
Hope that helps
[Edited on 15-10-10 by davrus]
big_wasa
posted on 15/10/10 at 06:22 PM |
Yeh you can buy a sheet full. I bought some for just the horn symbol.
If there is some you need I will see if I can find them for you.
Dash, Switch, Symbol Sticker Sheet, Rally, Kit Car, on eBay (end time 19-Oct-10 11:35:29 BST)![](http://rover.ebay.com/roverimp/1/710-53481-19255-0/1?ff3=2&pub=5574934589&toolid=10001&campid=5336738914&customid=&item=123456&mpt=[CACHEBUSTER])
Ninehigh
posted on 15/10/10 at 07:27 PM |
Paint them, I've had some cars that old and used it's worn off
iank
posted on 16/10/10 at 08:50 AM |
Labelling of switches is something that was tightened up considerably in IVA compared with SVA.
As you're doing MSVA I doubt it will be a problem, but check the manual. Fitting a sticker isn't much of a hardship though.
Anonymous
