New Topic New Reply
Author: Subject: whoops
chrisxr2
posted on 20/10/10 at 06:33 PM Reply With Quote
whoops
Pulled my dipstick out to check the oil today before taking the haynes roadster out and the bottom of the dipstick snapped of and tinkled off into the sump. Bugger. Tried everywhere to get a long magnetic attatchment to try that, looks like draining the oil and then probably removing the sump, not good. Anyone know if i will need a new gasket foe the sump?? or is there one? 1.6 pinto engine.
Life moves pretty fast, if you don't stop and look around once in a while, you could miss it.
posted on 20/10/10 at 06:38 PM Reply With Quote
It can't go up the strainer on the pick up pipe so don't worry about it. Look for a magnetic sump plug and change the oil to fit it. You will need a new gasket to refit the sump.
Strontium Dog
posted on 20/10/10 at 06:43 PM Reply With Quote
DP!
[Edited on 20/10/10 by Strontium Dog]
Strontium Dog
It may come out when you drain the oil if you're really lucky. I have a small magnet on an alloy shaft that would fit into most drain plug holes. Mines made by Facom but I've seen similar ones in the market and cheap tool shops!
As to the sump gasket you may get away with it and you may need some (apply sparingly) silicon instant bodge I mean gasket!
adithorp
posted on 20/10/10 at 06:45 PM Reply With Quote
Agreed. Leave it where it is, it'll do no harm. If you're worried either fit a magnetic sump plug or if you don't want to drain the sump, just get a strong magnet and stick to the side of the sump.
adrian
http://jpsc.org.uk/forum/
loggyboy
posted on 20/10/10 at 06:49 PM Reply With Quote
Use an old speaker, they have nice big magnets.
jacko
posted on 20/10/10 at 06:56 PM Reply With Quote
It's not a big job to remove / refit a sump no a pinto so why not do the job right ?
stevebubs
posted on 20/10/10 at 07:09 PM Reply With Quote
Ditto - I'd be paranoid about going over a bump at speed and it getting in the way of the crank...
Stuart_B
posted on 20/10/10 at 07:13 PM Reply With Quote
i would, just, drain the oil, hope it comes out, if i can not see it, take the sump off, and clean it out and re fit with a new gasket.
see i know last time i used a cheap gasket brand new, i lost all off my oil, when i was 30 miles away from home.
stuart
hillbillyracer
posted on 20/10/10 at 07:39 PM Reply With Quote
On a lot of engines I would'nt worry but on something that gets driven with enthusiasm, mabye hit a bump at speed etc I'd be always a bit worried too. I dont know that it'd manage to do much harm but it's bug me!
I once dropped the sump off a 6cyl tractor & found 3 small padlocks & a key that did'nt fit them, all small enough to fit down down the 30mm wide dipstick/filler pipe!
The owner had no explanation & he'd owned it from new, the rough cast finish of the sump was worn into the brass locks so they'd been there a while.
stevegough
posted on 20/10/10 at 08:37 PM Reply With Quote
er... what's a dipstick?
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
myke pocock
posted on 21/10/10 at 11:21 AM Reply With Quote
A dipstick? Just look at the current incumbent of Number 10.
Ninehigh
posted on 21/10/10 at 07:37 PM Reply With Quote
He's not too bad, it's the git at number 19 that annoys us! Staring out of his window and grumble grumble
chrisxr2
posted on 22/10/10 at 05:45 PM Reply With Quote
nope
drained the sump, no joy, awaiting delivery to ford of a sump gasket, all 37p of it.
jacko
posted on 22/10/10 at 06:41 PM Reply With Quote
If this helps you i clean the sump / engine block with degreaser then i stick the gasket on the block with evo-stic, then i put gasket paste on the sump
I also cut the head off 4 long bolts, screw them in the block to help you line every thing up
Jacko
chrisxr2
posted on 22/10/10 at 07:02 PM Reply With Quote
thanks
nice one thanks
New Topic New Reply
