dhutch
posted on 10/11/10 at 09:53 PM |
Tintop MOT without a BUMPER?
To cut a long story short i need an MOT on a car that doesnt have a bumper (due to i'll fitting OEM pug tow hitch) and while i know it possible
as long as there no sharp edges im wondering how best to cover them?
Thoughts? Got some u strip but only the all rubber stuff not steel cored. Glue it on?
Also need a numberplate light. Would a magnetic stick on battery powered one suffice?
Daniel
owelly
posted on 10/11/10 at 10:01 PM |
It depends on the guy doing the MOT. Strictly speaking, a battery light won't comply. Sharp edges should be covered and check the tail pipe
doesn't poke out. It shouldn't matter how the sharp edges are covered. Masking tape should do it but it does depend on the MOT guy.
http://www.ppcmag.co.uk
adithorp
posted on 10/11/10 at 10:04 PM |
Sharp edges pretty much comes down to testers opinion. Gaffer tape is often enough. If you're useing the rubber stick it with silicone; That way
it's easy to remove. Number plate light has to work from the light switch I think.
http://jpsc.org.uk/forum/
dhutch
posted on 10/11/10 at 10:20 PM |
Winner, i can plug something into the no plate light take off with some cunning im sure. Just no time to sort it before the weekend, totally forgot
about it needing renewing (for a few months) and just had a reminder in the forum of a £60 non-endorsable penalty. Not cool!
Daniel
PSpirine
posted on 10/11/10 at 10:48 PM |
Cling film should cover all the sharp edges nicely! you can do the whole car in one go ![](/images//smilies/bigsmile.gif)
blakep82
posted on 11/11/10 at 12:59 AM |
60 squid isn't too bad really, i think its a maximum fine of £1000? i take it its the back bumber thats missing (hence needing the number plate
light too?) then the sharp edges should be easy enough to sort, U trim stuck on should do. MOT is more concerned about razor sharp edges cutting
fingers if touched, that kind of thing. not radius requirements
________________________
dhutch
posted on 11/11/10 at 12:45 PM |
quote: Originally posted by blakep82I take it its the back bumber thats missing (hence needing the number plate light too?)
Yes, rear bumper.
I also agree that £60 is a small price to pay all things considered, partiuarly as point would have ment totting up ban.
Daniel
dhutch
posted on 12/11/10 at 05:19 PM |
Passed, winner. Looked quite nice by the time it was done to be honest, the grey tape is almost car coloured and with a lenght of inner tube behind it
very nicely radiused.
Got an advisory to for it too which is actaully good becuase it can be shown to any doubters.
Other than that, clean test for £38.
Daniel
