New Topic New Reply
Author: Subject: Aluminium plate waterjet cutting - recommend me someone?
MK9R
posted on 11/11/10 at 09:34 AM Reply With Quote
I need some 6mm dural/aluminium plate supplying cutting to my own design (for engine mounts). I will supply cad drawings or MDF mock up to the supplier. Can any one recommend a good company.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
mcerd1
posted on 11/11/10 at 09:42 AM Reply With Quote
andyw7de on here - drop him a u2u
[Edited on 11/11/2010 by mcerd1]
blakep82
posted on 11/11/10 at 09:44 AM Reply With Quote
Andyw7de! End of
________________________
MK9R
posted on 11/11/10 at 09:50 AM Reply With Quote
thankyou super knowledge LCB!!!
Cheers Austen
RGB car number 9
www.trackace.co.uk
Bluemoon
posted on 11/11/10 at 05:30 PM Reply With Quote
Are U sure you want to make em from dural/aluminium fatigue may be an issue (lot's of vibration on the mounts)..
flak monkey
posted on 11/11/10 at 11:19 PM Reply With Quote
Please dont make engine mounts from aluminium!
Sera
http://www.motosera.com
MK9R
posted on 11/11/10 at 11:29 PM Reply With Quote
Plenty other race cars do. I'm using the BDN as a example to copy, it has won numerous RGB races and been running with ali engine mounts and bulk heads for 3 seasons without a problem. Yes I know I will need to keep an eye on it for fatigue cracks, and probably life the components, but that's part of looking after a race car.
My steel engine mounts and chassis have both snapped in the past 2 seasons, so something I'm quite used to
Cheers Austen
RGB car number 9
www.trackace.co.uk
MK9R
posted on 11/11/10 at 11:31 PM Reply With Quote
Oh and plenty of cars out there using ali plates to mount the chain drivem diffs.
Cheers Austen
RGB car number 9
www.trackace.co.uk
flak monkey
posted on 12/11/10 at 07:47 AM Reply With Quote
If its for a purely track based car then OK, they will break eventually.
The only reason you would break steel engine mounts is because they are either designed incorrectly (basically not strong enough) or the fabrication was poor.
The fact you are breaking steel ones tells me aluminium ones are even more of a bad idea.
Diff mounts are a totally different kettle of fish as they dont see the vibration or loading that an engine mount would!
Sera
MK9R
posted on 12/11/10 at 07:49 AM Reply With Quote
Well it is a fury, full of terrible chassis "designs" and weak points
Cheers Austen
RGB car number 9
www.trackace.co.uk
welderman
posted on 12/11/10 at 07:57 AM Reply With Quote
hope not !
MK9R
posted on 12/11/10 at 08:06 AM Reply With Quote
hope not !
OK for road use, but the lowered race chassis used in anger always breaks in the same places, as does the fireblade engine cradle/ H bracket
Cheers Austen
RGB car number 9
www.trackace.co.uk
MK9R
posted on 10/12/10 at 07:39 AM Reply With Quote
Ended up using www.precisionwaterjet.co.uk, items received 7 days after sending them the cad drawing, excellent service, and the best price from all the quotes i had
Cheers Austen
RGB car number 9
www.trackace.co.uk
New Topic New Reply
