russbost
posted on 23/11/10 at 09:19 AM |
sand blasting, shot blasting etc.
Hi All
Looking for a bit of advice, I want a quick way of cleaning up donor parts, ideally I'd prefer to buy the gear & be able to do the job
onsite - I already have a decent compressor setup.
Now I know very little about the varioius blast cleaning methods, I know I can buy a sand blaster & cabinet quite cheaply, & I'm sure it
would get rust & crud off parts, but I'm concerned that no matter how well protected you'll finish up with sand getting in bearings
etc which would not be good How about shot blasting, or bead blasting, is this basically the same equipment, or is it something far more expensive?
& vapour blasting? what's that exactly? & costs of the above gear?
Guess the Q I'm asking really is, am I better to buy small(ish) cheap(ish) equipment myself or am I better to find someone good locally to farm
it out to?
Thanx in advance for any advice!
Edited to add, are any of the cleaning agents, like glass beads for instance reuseable or is it all thrown away?
[Edited on 23/11/10 by russbost]
dhutch
posted on 23/11/10 at 09:25 AM |
Also, if its not a high-jack, peoples thought on handheld blast equip such as the below.
http://www.machinemart.co.uk/shop/product/details/sb3-gritblast-gun/path/sandblasting-equipment-and-accessories
RazMan
posted on 23/11/10 at 09:46 AM |
Electrolysis has always been popular with people here - realtively easy to set up and very effective at removing rust without the risk of ruining
bearings.
Raz
balidey
posted on 23/11/10 at 09:47 AM |
We have a DIY made one from an old oil barrel.
You will need a BIG compressor, you need volume.
Obviously don't use sand. We are experimenting with different shot at the minute. But I hear crushed glass is good, but not used it yet.
I've also bought some baking soda to try on carbs and TB's etc.
One rule my dad has given me (he uses pro set ups at work) is that never put in an assembly. You must strip all parts down, ie if you have a brake
caliper, it has to be fully stripped or some shot will get lodged in where it shouldn't. No matter how well you think its cleaned after, its
not.
Dutch bears have terrible skin due to their clogged paws
balidey
posted on 23/11/10 at 09:50 AM |
Also, its a lot slower process than I thought. I pressumed its would blast away all crud in seconds, but when using it you have to work quite slow
over the parts. A small exh mani took me a good half hour to do a 'quick' blast over.
But the results are pretty good.
Stott
posted on 23/11/10 at 09:53 AM |
You can use a lot of different media in for instance, an ebay sand blast cabinet. Some are more aggressive than others but the net effect for our
purposes is about the same.
I have used lead shot, iron oxide sand and bead.
Lead shot took everything off very quickly and left the parts looking lead coated, if you know what I mean. It didn't change the surface finish
too much and the parts are now some of the toughest I've ever painted (you need a flap disc in a grinder to remove plastikote off them!)
Iron, well wow. It took everything off and some of the metal. It came out feeling like 60 grit sandpaper and I had to de-nib the parts which took
hours. Super pain in the butt, and the finish isn't suitable for paint untill you have rubbed it down for a long time.
Beads: That worked well, did a pinto head with this and in all fairness it looked new. It didn't mark the cam bearings despite them being left
in there (albeit they weren't aimed at) so it is quite an unaggressive media. The finish was brilliant and ready for paint and it didn't
change the surface finish of the metal at all.
Sand, well normal grit if you will, the stuff that feels like sand. I find this to be very tiresome. I recently tried to get some powdercoat off with
it and it was taking all day. I ended up hitting it with a knot wheel then using the sand to even out the surface finish. However this stuff is good
for say, frosting perspex parts, or designs onto perspex/metal. You can mask up logos and blast them into parts you make which looks really cool when
it's done. However it's not enough to take rust off. It can't even budge the surface rust that was on my front grille without a few
passes.
On balance I'd say the lead stuff was the best overall. I did some alloy wheels though in that cabinet and they did come out a little peened
looking. But for cleaning up parts such as suspension arms, hubs, blocks, etc it was ace. For alloy heads, rocker covers, brackets etc I'd be
inclined to use one of the roughest sand type grits available.
As for it getting everywhere. It just does, no matter what the media it will get everywhere, behind seals, in oilways, in every thread etc etc.
It's a potch, but as with everything it's a time vs finish balance. Given how quickly you can turn a part to bare metal, an hour cleaning
a head for instance, and running taps up the threads etc to clean it out seems worth it to me.
If you have enough to do in order to warrant buying a machine I'd get one myself as they are very handy. They do take up a bit of room though
and are messy as the dust goes everywhere despite the cabs being sealed. A garage I worked in bought a blast cabinet that was capable of fitting 2
alloys at a time in from a liquidation auction along with some other bits. It was floor mount with a side door and foot pedal operation. That was the
absolute business. The nozzle was about 1/2" diameter and like the end of a hose pipe which made it very pleasant to use.
I'd recommend one with a pedal if you do buy one as it quickly becomes very annoying to have to squeeze the trigger and jet the shot all around
the part. You end up with hand cramp in about 5 mins.
That's my 5p worth Russ, I'm no professional shot blaster though so feel free to disregard any of the above!
Stott
big-vee-twin
Someone on here messed up a diff by shot blasting the complete assembley, I belive he had to have it professionally rebuilt
http://www.triangleltd.com
Stott
posted on 23/11/10 at 09:58 AM |
I concurr^^
Although with the lead shot I was on about it would nearly hurt your hand if you caught the glove with the jet of it and it would matt off the rubber!
Using that media I could take a typical alloy wheel to bare metal in well under 10 mins. Using the more sandy stuff I'd guess it would have been
2 hours work based on my experience with it.
Again though, a good cabinet is a must IMO the one I was on about would push your hand back when it was flowing so it was a proper high pressure
blast. The diy cabs I've used seem more akin to an air dust gun in the pressure they exert.
Stott
myke pocock
posted on 23/11/10 at 10:08 AM |
I have used alluminium oxide and glass bead in various grades. Alluminium oxide is very aggressive as it has sharp edges and leaves the surface rough,
perfect for a paint finish. Glass bead works more on an inpact principle rather than cutting as it is like microscopic marbles. Great on alloy if you
also want a decorative finish and looks good if you mask the surface with, say brown packaging tape or sticky back plastic, cut it away to expose the
surface then blast it. I did an alloy wheel boss for my JC Midge with a logo years ago and once its there it aint gona go anywhere. I have also done
carbs but masked the mating surfaces and stripped down completely. As has been said, compressor capacity is critical. There are loads of other
abrasive media, crushed walnuts, cork (believe it or not) plastic bead etc.
thunderace
posted on 23/11/10 at 10:24 AM |
here is what i would advice you to do enjoy my post on the scotish vag forum on blasting
i have 3 diferent blasters
1 for a jetwash (5/10)
1 for a compressor (8/10)
1 homemade soda blaster that works the best.( 10/10)
enjoy
http://www.scottishvag.net/phpBB3/viewtopic.php?f=101&t=37527
Bluemoon
Used the bead blaster at work for a lot of parts, fantastic! Sierra uprights wishbones ect, all steel great surface for painting onto. Even did the
uprights WITH the bearings in you can do it BUT YOU MUST MASK THE AREAS VERY CAREFULLY, including the tapers ect (a box of rubber bungs are what you
need, leave them it for painting as well). I successfully masked the bearings with a lot of string wound around the axle covering the area, then
covered this in many layers of tape. Id doing this professionally I would suggest re-building with new bearings as you might get grit in! After 1.5K
my bearings are find so it is possible, but on a customers car/parts this is asking for trouble..
Anything that could not be bead blasted (to big not/not time to take into work) was done the best I could (electrolysis wire brush, emery, degreased
etc) then etch primed to make sure the paint stuck, as worked really well. Only thing I regret is not using a exterior gloss top coat as this is more
chip resistant than the chassis black I have.
Dan
[Edited on 23/11/10 by Bluemoon]
alexg1965
posted on 23/11/10 at 11:18 AM |
I have the smaller Clarke blasting cabinet (the one that's a glove box) and use their aluminium oxide grit. To feed it I use two 3hp compressors
(I don't have anything other than standard 240V, single phase domestic sockets in the garage) which I would say is the bare minimum. For
cleaning up stuff, I think it's brilliant and much easier than using wire brushes although I've never tried the electrolysis approach. The
only thing I would say is that the window gets obscured very easily and it soon becomes almost impossible to see what you're blasting. So I
either use "feel" to gauge where I'm blasting or do it with the lid open and lose a load of the grit.
balidey
posted on 23/11/10 at 11:44 AM |
do the little Clarke ones not have a vacuum cleaner attachment?
We built one into ours behing a baffle and it keeps the air inside fairly clear of dust.
blakep82
posted on 23/11/10 at 11:49 AM |
isn't there something about using crushed walnut shell as a blast media? apparently its quite good. think it was on american hotrod i saw it?
________________________
Bluemoon
posted on 23/11/10 at 12:17 PM |
quote: Originally posted by alexg1965
The only thing I would say is that the window gets obscured very easily
.... do it with the lid open and lose a load of the grit.
Only do this if your have the correct dust mask (not cheapo one either). You don't want to get silicosis ect.. Having a vaccum (i.e. negative
pressure via a heppa filter+vacuum cleaner) is the best idea.
As to obscuration, you can get ripoff covers for the perspex window use these (so you don't sandblast the perspex!).. I would never operate with
the box open.
Dan
tony-devon
posted on 23/11/10 at 01:28 PM |
crushed walnut shell is great for polishing brass, I use it in a vibratory cleaner to clean all my brass gun cartridges before reloading them.
vapour blasting leaves a nice finish on ally.
and as mentioned above I regularly get vinyl logos etc cut at local sign shop, then use them as templates to frost perspex and brass etc
also use the sandblast cabinet to give a matt non reflective surface on red acrylic etc when I have made custom tail lights for bikes, it just adds to
the overall effect
heavy is good, heavy is reliable, and if it breaks, hit them with it
russbost
posted on 23/11/10 at 01:29 PM |
Thanx for all the info so far. Hadn't realised they were so energy consuming re the compressor, I have a 3HP with a big tank & won't
want to do a lot at a time, but still sounds like it's likely to struggle.
One thing I'm not clear on, if I buy something like a Clarke or Sealey for about £250 is it going to handle stuff like glass beads & lead
shot or do you have a different gun for that?
interestedparty
posted on 23/11/10 at 01:50 PM |
I believe the gun in the cabinet has 4 different nozzles supplied with it, some kind of ceramic, so use the one that gives the best result, obviously
the bigger the nozzle the greater the flow but the lower the velocity.
A big cabinet give more room for the air to circulate, and allows a vacuum, [plugger into the cabinet near the top, to extract the dust while the
heavier grit drops back down into the hopper.
alistairolsen
posted on 23/11/10 at 05:31 PM |
Personally, I wouldnt be worrying about bearings at all. There isnt a chance Id be taking donor parts off a car and re-using service items with an
unknown life.
My Build Thread
fazerruss
posted on 23/11/10 at 06:41 PM |
Forum Code:
![](/galpreviews/Copy of front.JPG) ![Description](/gallery/Copy of front.JPG) Description
Heres my set up. you can use a 3hp compresser mine is a clarke 14cfm with 50 litre receiver. my dad made the cabinet for his business many years ago.
He had a look at the Gyson cabinets but he thought they were crap and very expensive and after seeing one I agree! The secret to using a small
compressor is to directly tap off the tank rather than using the built in regulator which is quite restrictive. I removed the 3/4 bsp plug and fitted
the required valves and connectors but the main difference is the blast cabinet is fed with 1 inch diameter hose to a bigger regulator then foot
pedal. The blast nozzle is about 5/8 and will go at 90 PSI constantly using paving sand to good effect. I use a wood vac to keep the cabinet clean
(4inch pipe)
"if assholes could fly this place would be an airport"
tony-devon
posted on 23/11/10 at 08:33 PM |
I use a clarke cabinet that we have then modified larger, my own home made lid, new 6mm thick acrylic top, with tear off 1mm thick clear inside, so
that when it becomes misty and obscured, you just tear that out and stick a new bit in
mines run at 100psi and the compressor is rated 44cfm at 100psi, plus a 420l tank runs happily no problems
russbost
posted on 25/11/10 at 08:27 PM |
Thanx for all the info guys!
