Author: Subject: Steering wheel exempt zone and aeroscreens
Davegtst
posted on 15/12/10 at 07:47 PM Reply With Quote
I seem to remember reading that if an aeroscreen is fitted the 127mm interior projection exempt zone around the steering wheel doesn't apply. Is this right as this will affect what type of ignition switch i fit to my dash.
andrew
posted on 15/12/10 at 07:57 PM Reply With Quote
fit screen after test
russbost
posted on 15/12/10 at 08:37 PM Reply With Quote
As I understand the regs if you have NO screen at all thenyou lose the exempt zone, providing you have some form of screen to differentiate between the interior & exterior of the car then you should have the exempt area
Macbeast
posted on 15/12/10 at 09:00 PM Reply With Quote
I went for IVA today without any screen and they seemed to be saying with no screen the exempt area extends to the outside of the scuttle. I wan't about to argue
I think also they were saying that no screen makes a difference to what is regarded as interior or exterior projections.
[Edited on 15/12/10 by Macbeast]
Davegtst
posted on 15/12/10 at 09:38 PM Reply With Quote
Thanks for the replys. As i understand it any kind of screen shouldn't make any difference at all. The only mention of the screen i can see is 'area C' which is the windscreen pillar, which i won't have. Very confusing this.
russbost
posted on 16/12/10 at 09:14 AM Reply With Quote
I have simply repeated exactly what I was told by a tester who failed an item directly behind the steering wheel (ie defo what would normally be the exempt area) for a sharp edge - we fitted a 1" high 6mm thick perspex "screen" & he was then perfectly happy!
Davegtst
posted on 17/12/10 at 01:37 PM Reply With Quote
Do you think the same would apply with a carbon mods aeroscreen?
russbost
posted on 17/12/10 at 02:05 PM Reply With Quote
So far as I could establish all they were interested in was that something defined the break between inside & outside - so yes
