New Topic New Reply
Author: Subject: testing emissions at home? Where to find limits?
franky
posted on 19/12/10 at 09:08 PM Reply With Quote
anyone know the cheapest way of doing the above?
I'm hoping to get my kit tested at pre- 95 levels. its a 1993/4 bmw m3 3.0 engine, it did have a cat fitted but some of the early ones didn't.
Or does anyone know if my engine is in the IVA testers engine bible?
adithorp
posted on 19/12/10 at 09:25 PM Reply With Quote
If you have proof the engine is pre 95 then it only has to meet the pre 95 limits. They are <3.5% CO and <1200ppm HC. CO+HC can only be reliably checked with an exhast gas meter. You can try using a ColourTune but it's not entirly reliable.
http://jpsc.org.uk/forum/
franky
posted on 19/12/10 at 09:33 PM Reply With Quote
Cheers for that, I can prove its pre 95 as I have the v5 etc as it was my 'single donor'.
I thought it would be those higher limits it'd be tested to but some have said if the original car/donor was in thier 'bible' it might be tested to those limits.
would it be worth ringing local test places to find out what they say?
adithorp
posted on 19/12/10 at 09:51 PM Reply With Quote
It gets tested to the level for the vehicle if there is an exact match in the list. Your kit won't be in the list. It isn't a BMW so it can't be tested as one.
franky
posted on 19/12/10 at 10:00 PM Reply With Quote
You've made me a very happy boy
stevebubs
posted on 19/12/10 at 10:11 PM Reply With Quote
Not sure the V5 is proof enough any more...is there a Haynes manual or something detailing years of engine manufacture against serial number?
Alternatively, letter from manufacturer...
franky
posted on 19/12/10 at 10:21 PM Reply With Quote
I would have thought old mot's/original v5/engine number etc etc would have been enough?
Macbeast
posted on 20/12/10 at 10:33 AM Reply With Quote
Just had mine done and the V5 was sufficient proof of age ( the engine number matches that in the V5 )
martyn_16v
posted on 20/12/10 at 10:20 PM Reply With Quote
I just had mine done, and me saying 'er, it's a 93' was enough for my tester
New Topic New Reply
