stevec
posted on 29/1/11 at 06:01 PM |
Bike carb angles
Does it matter if bike carbs are fitted to an engine at a different angle than originally fitted to the bike? for example a carb with a float bowl
that was originally horizontal and is now tilted forward say 30deg. Will that have a bad effect on fuel level in the float chamber.
Cheers.
Steve.
r1_pete
posted on 29/1/11 at 06:05 PM |
They seem to be quite forgiving angle wise, when I did mine, I had the manifold made so it set them at the same angle as on the bike.
IMO keep the float chamber gasket face as horizontal as possible.
jacko
posted on 29/1/11 at 08:55 PM |
This is a photo off Bogg Brothers web site of a rover v8
[Edited on 29/1/11 by jacko]
RAYLEE29
posted on 29/1/11 at 10:12 PM |
ooh that yellow one looks like a tr7v8
anyone want one? got one in the garage that doesnt get used lol
well they obviously work like that so must be ok
ive kept mine at the same angle as they were on the bike they came off
Ray![](/images//smilies/smile.gif)
DarrenW
posted on 7/2/11 at 05:33 PM |
Logic would say try to keep them at a similar angle to that on the bike, but of course bikes are rarely upright and do occasionally go up and down
hills.
I had an in depth discussion with Boggs about this some time ago, and the conclusion was that it doesnt really matter. I angled mine so that the air
filter cleared the chassis. They used the V8 install as a proven example.
blakep82
posted on 7/2/11 at 05:50 PM |
i think the only difference is how much fuel they hold in the bowl before opening or closing the valve. i should imagine as long as they're not
upside down, they should work reasonably well.
eg if horizontal, they might only fill up a quarter of the way they normally would when fitten originaly. should be fine in a car i think, since they
don't change angle too much.
i hope anyway, mine are not fitted the same as in the bike
________________________
