posted on 22/2/11 at 06:38 PM |
Running 'Stuff' Through the Trans Tunnel
My car is already road registered, so IVA intricacies are not essential. That said, I want to be sensible, so there won't be anything overly
daft - I want it to remain MOT and C&U friendly.
Can I run the following through the trans-tunnel:
Steel braided fuel lines
Steel braided brake lines
Electrical Wiring in a... yep, you guessed it... steel braided hose
It's Evolution Baby!
jacko
posted on 22/2/11 at 06:43 PM |
Yes why not all my brake / fuel / wires run though the tunnel
blakep82
posted on 22/2/11 at 06:44 PM |
of course lol why wouldn't you?
________________________
PSpirine
posted on 22/2/11 at 06:46 PM |
As safe a place as any, if not safer than under!
Having said that, I'd probably want to make sure you've got a prop retainer of sorts (regardless of whether you're running
pipes/wires down there).
snapper
You can however I would question using steel braided, fuel hose can weep, brake hose can flex, steel or copper fuel line and copper brake hose is more
durable and a lot cheaper.
Some form of protection incase the prop let's go, I know people that this has happens to.
I don't know why more people don't use a false tunnel top and run it all through there, easy to get at.
I eat to survive
I drink to forget
posted on 22/2/11 at 06:48 PM |
Dunno... was sure I read somewhere that there were rules and regs surrounding what you ran through the tunnel and what you ran it in!
I could of course be talking a load of pish... it does happen from time to time!
blakep82
posted on 22/2/11 at 06:53 PM |
nah, the iva just says it has to be fit for purpose basically, and adequately supported.
so as long as its brake hose, and fuel hose, its spot on
posted on 22/2/11 at 07:04 PM |
Thanks people! I'm off to ebay!
plentywahalla
posted on 22/2/11 at 07:10 PM |
Just questioning the use of braided hose. Why use a component that is more expensive and has a shorter service life than copper pipe, when the
benefits of flexibility are not necessary?
I have used copper pipe and then fitted it inside thick walled neoprene tubing sealed at both ends. This has the corrosion resistance of copper, and
also the impact and abrasion resistance of neoprene in an exposed location. And its neat and cheap.
posted on 22/2/11 at 07:16 PM |
I hear what you're saying, and agree you're probably right... but I just think braided looks better.
franky
posted on 22/2/11 at 07:21 PM |
I don't see the worry with braided hose's. They've been used on bikes for years, they're only small runs too. They can
flex/move and are easier to work around. Plenty of pukka race cars at goodwood have fully braided systems so they can't be bad
plentywahalla
Only the hedgehogs will see it! ... and they will be squished and unable to tell anyone.
[Edited on 22/2/11 by plentywahalla]
mcerd1
posted on 22/2/11 at 08:11 PM |
just remember to fit propcatchers too
40inches
posted on 22/2/11 at 08:34 PM |
Do a search for braided fuel hose, it seems that it is not a case of if it weeps, but when
One here http://www.locostbuilders.co.uk/viewthread.php?tid=130196
[Edited on 22-2-11 by 40inches]
posted on 22/2/11 at 08:39 PM |
Again... you're right. But Hedgehogs like bling too!
bi22le
posted on 22/2/11 at 10:33 PM |
Is this not just unneccisary weight aswell?
Mind you just have a cr@p before hand and that will off set the cable weight!
Please read my ring story:
franky
posted on 22/2/11 at 11:56 PM |
I'd only ever use it in the braking system. You get what you pay for with hoses remember too!
