Hammy360
posted on 28/2/11 at 12:39 PM |
GBS Zero - Rear brake pipes
I'm installing my brake pipes and the t-piece has for conections one input from the front/master cylinder and has 3 outlets for the pipes, can
anyone tell me why? I have the pipes loosely connected and slightly baffled.
Shaft, if you are reading I looked at your photos but couldnt see too well. Can you help?
Flamez
posted on 28/2/11 at 12:43 PM |
Master cylinderto front brakes 2 pipes, rear brakes 1 pipe
my build mac1motorsports
Hammy360
posted on 28/2/11 at 12:46 PM |
I'm just talking about the rear brakes at the moment ie the t-piece fitted to the rear of the chassis to split off to the two rear calipers.
Flamez
posted on 28/2/11 at 12:57 PM |
Sorry don't know then.... Mine is a definate t piece 1 in 2 out.
flange nut
posted on 28/2/11 at 01:12 PM |
Could the third outlet be for a brake light pressure switch?
Geoff
zoom
posted on 28/2/11 at 01:16 PM |
On mine I have a 3 way connector at the rear and the brake light switch on the front circuit, but I know that Richard did fit the brake light switch
on the rear circuit so the 4 outlet mush be for that.
Marcus
mycar
mybuildsite
Hammy360
posted on 28/2/11 at 01:32 PM |
Cheers to you all
tomgregory2000
posted on 28/2/11 at 01:40 PM |
DONT fit the brake light switch to the rear circuit, fit it to the front!! as there is more chance of it working with the higher pressure in the front
lines
[Edited on 28/2/11 by tomgregory2000]
shaft
posted on 28/2/11 at 02:08 PM |
Hi Hammy,
As previously mentioned, the 4th outlet is for the brake light pressure switch. If you're using the GBS supplied loom it's wired to be
fitted in the rear tee piece.
As for extra pressure in the front circuits????
You could operate the switch by blowing in it, they don't need much pressure.
On another note, ensure you fit a Nylok nut on the retaining bolt when fitting the tee piece.... The IVA peeps like it that way.
Nick.
my opinion might be wrong you know...
My Zero Build Pics
gavin174
posted on 28/2/11 at 02:11 PM |
I believe it maybe an IVA fail to fit it in the rear circuit
But not 100 % sure
zoom
posted on 28/2/11 at 02:16 PM |
Hic!!
mycar
mybuildsite
Hammy360
posted on 28/2/11 at 02:23 PM |
quote: Originally posted by shaft
Hi Hammy,
Nick.
Cheers, I checked with GBS and they said the same
Alfa145
posted on 28/2/11 at 02:35 PM |
But not 100 % sure
100% incorrect as Shaft's must have passed with it there.
AndyW
posted on 28/2/11 at 05:09 PM |
But not 100 % sure
You are 100% correct![](/images//smilies/bigsmile.gif)
posted on 28/2/11 at 05:51 PM |
Yes car pass all the time with it in the rear circuit but very strict interpretation of the Road Traffic/Construction & Use acts would require
the stop lights to operate from the front brake circuit. The requirement is a carry over from the pre-ww2 days of mechanically operated brakes.
