New Topic New Reply
Author: Subject: What tyre pressure
chrisxr2
posted on 13/4/11 at 02:54 PM Reply With Quote
What tyre pressure
Had a search of the forum and not found a concrete answer. 1950 50 r15's on the haynes roadster, pinto engine im about 15 stone. What sort of day to day running tyre pressure??? Mxs5 with similar rubber is 28 psi. Thanks in advance.
Life moves pretty fast, if you don't stop and look around once in a while, you could miss it.
dunk3
posted on 13/4/11 at 03:16 PM Reply With Quote
I have 195/50/15 toyo proxes4 , and have them at 18psi all round.
[Edited on 13/4/11 by dunk3]
Bluemoon
posted on 13/4/11 at 03:17 PM Reply With Quote
Depends on the tyre type not just size, I run 18-20psi with standard road tires. Side wall stiffness is also a factor, hence different tyres give different results..
Dan
DRC INDY 7
posted on 13/4/11 at 03:20 PM Reply With Quote
im now running my toyo 888s at 18psi and finding them a lot better
chrisxr2
posted on 13/4/11 at 03:38 PM Reply With Quote
thanks all
28 is a wee bit high then, will try 18 to 20. Thanks all.
dhutch
posted on 13/4/11 at 04:52 PM Reply With Quote
Rightly or wrongly i also aim for around 18psi all round cold tyre pressure. R13 185 60 Bridgestone RE720's.
I also run simular in in the A038's front which are 185 and about the same in the rears althoughthere are 205.
No reason other than this appeared to be what others where running and gives the sort of deflection i would expect, my tyres started and heavly part worns and the cars use is suffenctly light that im unable to gauge if this is right from wear rated over the tyre. But on track the tyre temps dont feel awfull given that cars hardly setup and im using the back of my hand as a temp probe...
Daniel
New Topic New Reply
