New Topic New Reply
Author: Subject: where can in find a scew in hose fitting?
franky
posted on 25/4/11 at 04:46 PM Reply With Quote
my new engine needs a 5bar fuel pump, i've got one however i've decided to run a twin in tank set-up like the DTM race cars did.
I need to create a fuel return fitting on my tank.
I'd like to drill the tank and fit a hose connector like this...
BRASS HOSE CONNECTOR 1/4' BSPT - 5/16' 8mm HOSETAIL 2pk | eBay UK
However i'm looking for one that will bolt either side of the tank if that makes sense? Not a screw in one.
Any pointers?
big_wasa
posted on 25/4/11 at 04:54 PM Reply With Quote
https://secure1.actinicexpress.co.uk/shops/partsforaircraft/index.php?section=64
7th down on the right.
Not exactly what you asked for but just an idea.
[Edited on 25/4/11 by big_wasa]
franky
posted on 25/4/11 at 05:21 PM Reply With Quote
yep, cheers for that, just found these too, an M10 nut on the back should do the trick also.
M10 x 1.0 Thread to 8mm I/D Hose Fuel Connector on eBay (end time 08-May-11 14:22:01 BST)
New Topic New Reply
