New Topic New Reply
Author: Subject: Damage Repaired - Well sort off!!
Krismc
posted on 28/4/11 at 05:29 PM Reply With Quote
You may have seen the post a while back when a box fell out of my loft in the garage and caused a bit of damage too my tunnel, which was reported as unrepairable by a few off you, it doesnt look that bad but every one has spotted it as its a hole right through!! -
Well the other day while machine polishing the car (dont worry it wont happen again it took 4hrs) i decided that if i cant repair it ill hide it- GREAT SOLUTION
BEFORE
AFTER
Yes theres 5 other cracks and marks caused by the same bloomen box, but they are less noticable now
[Edited on 28/4/11 by Krismc]
Krismc
posted on 28/4/11 at 05:33 PM Reply With Quote
And a pic of the car with shine ....Sort of
mad-butcher
posted on 28/4/11 at 07:23 PM Reply With Quote
Don't know why, but I have a gut feeling about chassis number on public display, maybe I've reached that untrusting age.
good solution though
SteveWalker
posted on 28/4/11 at 07:43 PM Reply With Quote
All the tin-tops I've had in the past 15 years have had it on a plate in the windscreen.
lotusmadandy
posted on 29/4/11 at 10:37 AM Reply With Quote
I like it,where did you get that made??
blakep82
posted on 29/4/11 at 11:01 AM Reply With Quote
cars all have them in the corner of the windscreen! next you'll be worried about showing your reg number on a public highway
i like it. better than just 'a sticker'
[Edited on 29/4/11 by blakep82]
________________________
stevegough
posted on 29/4/11 at 11:17 AM Reply With Quote
quote
"Yes theres 5 other cracks and marks caused by the same bloomen box, but they are less noticable now"
Doesn't matter - the label draws the eye - YOU see them because you know they are there - no-one else will.
Great solution. Great result.
(You could also have put a dummy gear transfer box lever - 2WD / 4WD - that would have been even more cool!)
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Krismc
posted on 29/4/11 at 01:51 PM Reply With Quote
My mates, mate made it, 3 off £20 covered the stamped ones on chassis too.
New Topic New Reply
