macspeedy
| posted on 11/10/11 at 12:21 PM |
trying to make floatation tubes for a boat
I have a boat project nearing completion, i had looked at expanded polystyrene wrapped in shrink wrap as a floataion safety device incase the hull is
holed.
But recently i had the idea of using car inner tubes. Then i thought what if you cut them and laid them flat having sealed up the ends...
the question is would rubber cement be enough if the ends where properly prepared to keep the air in ?
thanks
Mac
[Edited on 11/10/11 by macspeedy]
liam.mccaffrey
| posted on 11/10/11 at 12:32 PM |
what about expanded PU, isn't that what they use on "real" boats?
Build Blog
Build Photo Album
designer
| posted on 11/10/11 at 12:33 PM |
On my old fibreglass boat I filled all cavities with 2 part foam.
[Edited on 11-10-11 by designer]
Confused but excited.
| posted on 11/10/11 at 12:39 PM |
Inner tubes can also puncture, therefore they are of no use whatsoever.
Use foam and make sure that the foam that you do use, is closed cell foam.
Irony
| posted on 11/10/11 at 01:08 PM |
Dunno much about boats but be careful of the two part expanding foam. To much with nowhere to expand to and it'll crack steel cases wide open.
You also literally have seconds after mixing some types of the stuff.
emsfactory
| posted on 11/10/11 at 02:26 PM |
Sorry if this is a bit cheeky,
I have this available
eBay - The UK's Online Marketplace
owelly
| posted on 11/10/11 at 03:09 PM |
I made the mistake of using builders expanding foam in my boat. I thought the trailer looked to be carrying a bit of weight then realised the foam had
sucked about two tons of water inside itself! I had to spend a whole weekend chipping soggy foam out of all the places I could fit into.
http://www.ppcmag.co.uk
macspeedy
| posted on 11/10/11 at 03:14 PM |
btw its a 15ft boat
snakebelly
| posted on 11/10/11 at 03:56 PM |
£99! youve got my evil mind working now....... wonder what would happen, scrap car with sunroof + 300l expanding foam......
| posted on 11/10/11 at 04:40 PM |
Now you know why you should use closed cell foam.
Don't beat yourself up owelly. You ain't the first to make that mistake.
iank
| posted on 12/10/11 at 05:24 PM |
Indeed as found out here http://www.blatchat.com/T.asp?id=2911
(scroll down to "And this is how not to do it:"
Anonymous
