monck
posted on 25/12/11 at 01:15 PM |
Machining required asap ......
Hi i am currently on a mission to get my engine back in my car as im off over Christmas hence i need a quick hand ....
Engines all ready bar the flywheel , I go to fit it (Tiger lightened flywheel ) and socket just keeps slipping of the bolts i cant even get 10nm let
alone 120 nm ....
Turns out after a quick search that this is a design floor .. Some say use washers some say don't as its dangerous
I thought ill use the washers be ok untill i saw this http://www.youtube.com/watch?v=L2pz1PkhAo8 i like my legs so i want it done properly no risks
This link about half way down thew page shows you what i need doing http://www.toyne.org.uk/kc-mods-engine.html
monck
posted on 25/12/11 at 01:16 PM |
Have to be within reasonable driving distance of cw5
NigeEss
posted on 25/12/11 at 02:06 PM |
So what you require then is a socket with the outside turned down a bit.
I'm not that close, about 45mins and also in Dubai till Friday, but have a lathe so could help
if you get really stuck.
fazerruss
posted on 25/12/11 at 02:10 PM |
I thought its the bolt seats on the flywheel that need machining bigger?
Ive got the kit to do it but it would be a PITA
"if assholes could fly this place would be an airport"
monck
posted on 25/12/11 at 02:35 PM |
I have solved the problem, Not the brightest idea ever but i found a spark plug socket witch was not as thick as the normal ones but still
wouldn't go on the bolt right
i threw it on the floor in frustration ..... Then i noticed the angle grinder
I butchered the end of the socket with the grinder so the end of the socket was very thin and i managed to touqe my bolt all to 112nm witch im told is
right ..
That will do me for today im going to have my Christmas dinner and a few beers ..... Hope your all having a good Christmas also ![](/images//smilies/bigsmile.gif)
RK
posted on 26/12/11 at 02:06 PM |
Ingenuity is what builds these cars! Have a happy holiday!
