Author: Subject: Floorpan in 18swg Aluminium
jimmy
posted on 13/9/02 at 05:32 PM Reply With Quote
I have some aluminium sheet 1.6 mm thick spare and was wondering if the sva man would object to me using it for the floorpan?
I know I will have to weld in some 3mm thick strips to mount the seats on as the ally would'nt be strong enough.
Cheers Jimmy
stephen_gusterson
posted on 13/9/02 at 06:06 PM Reply With Quote
1.6 mm is actually 16 swg.
you will absolutely need to add some kind of extra support for the seats, even on a steel bottmed car.
the 'book' car used a bench seat, but a normal sliding seat puts 'spot' loads where it bolts down. if its not bolted flat to the floor, the floor will move and 'ping'.
I would suggest you did as I did - just weld another one or two 1 inch sections across the floor and bolt through those. they will be a lot stronger and less flexy than a 3mm thick strip, which at say 3mm by 40mm is approx the same mass as a bit of square section anyway!
atb
steve
