chris-g
posted on 19/1/12 at 03:15 PM |
Caravan trailer / transporter conversion
Hi All. Due to me having a narrow drive, I am planning on building a transport trailer that will fit my requirements. I have been looking at using a
caravan chassis as the basis of the trailer. Having researched the net and this forum, it seems it is quite common to convert a caravan, but I have
also come across a number of negative comments regarding their suitability. I would appreciate any thoughts, comments, experiences good or bad from
those who have built and/or used a caravan based transporter. It will be used for a 7 type car weighing in the region on 600-700kgs.
Thanks for reading.
[Edited on 19/1/12 by chris-g]
jacko
posted on 19/1/12 at 05:12 PM |
I would not use a aluminium caravan chassis , apart from that why not as long as the weight is not over the axle specifications
rj
posted on 19/1/12 at 05:24 PM |
I built mine from a twin axle caravan chassis, its galvanised steel. Its been brilliant, used it for my Nova rally car, then a friends Impreza rally
car, and now the MK, tows very well, dosnt wiegh a lot and fits thro a std garage door
rpm
posted on 19/1/12 at 05:53 PM |
i built one from a single axle chassis but added a second axle which i got with the chassis as a spare( £50 for the whole lot), it towed
fantastically solid as a rock at 70. make sure you spend time working out the axle position/weight distribution if you do this, but it's a
cheap way of getting a good trailer
big_wasa
posted on 19/1/12 at 08:15 PM |
I made one, never had the car on it but did use it for general stuff and it towed great. I will look out for another in a few months as I sold the
last one.
vyperstrype
posted on 19/1/12 at 10:04 PM |
I converted a single axle Alko caravan chassis a couple of years ago for carrying the Indy about. It tows superbly on the motorway, and weighs next to
nothing. Also as said before it all fits into a standard garage. I paid £80 off ebay for mine and was lucky that without modification i was able to
get on and off the trailer bed between the tyres on the trailer, which was a worry but you can always widen the axle beam.
I enjoyed making mine and would highly recommend converting one.![](/images//smilies/smile.gif)
Where there's a will, there's a death!!
tul214
posted on 20/1/12 at 06:17 AM |
I did it. £50 for the caravan chassis and £150 for steel.
When my car sold I sold the trailer for £350
![](/galpreviews/HPIM3296.JPG) ![trailer3](/gallery/HPIM3296.JPG) trailer3
![](/galpreviews/3trailer2.jpg) ![trailer2](/gallery/3trailer2.jpg) trailer2
1.6 Raw Super6 sold
dhutch
posted on 20/1/12 at 10:54 AM |
Looks tidy.
- Did you ever weight it or have it weighed?
- Would be interesting to know how light you can get it.
Daniel
tul214
posted on 20/1/12 at 12:35 PM |
Looks tidy.
Daniel
Never weighed it but it was quite strong. I probably overdid it with the steel but it towed well and was pretty easy to man handle into the garage,
even with the car loaded.
Bit of a pain having to sort the ramps etc everytime I wanted to go out though. Definately a lot easier if you can store it somewhere.
Mark
1.6 Raw Super6 sold
SPYDER
posted on 20/1/12 at 02:30 PM |
Mark, what was the noseweight like on your trailer. The pics show the car well forward of the trailer axle. Did this make the noseweight excessive?
Geoff
tul214
posted on 20/1/12 at 06:08 PM |
Never actually weighed the nose either
I pulled the trailer/Tiger with my dads ML and a diesel mondeo I had at the time. Neither had any problems and neither 'looked' nose
heavy.
1.6 Raw Super6 sold
chris-g
posted on 20/1/12 at 09:57 PM |
Thank you for all the responses. A good bit work there Mark, it looks spot on. I am sold on the concept so its time to start looking for suitable
donor.
I might have to think about making the trailer narrower, probably the same width as the car so that I can get past it when its on the drive. Does
anyone know how the axle and centre tube is constructed? Could a piece be cut out of the tube that connects the axles together and then be welded
together with suitable reinforcement?
