TimC
posted on 17/2/12 at 12:59 PM |
Oh dear: £18k.
locost megabusa turbo | eBay
On the plus side, the motor looks sweet...
tegwin
posted on 17/2/12 at 01:08 PM |
Christ..that is quite some asking price!
www.verticalhorizonsmedia.tv
steve m
posted on 17/2/12 at 01:10 PM |
One of the worst ads ever and 18k, what a joker,
£1800 possibly ?
and his spelling, is woorse than mine,
hahahaha
monck
posted on 17/2/12 at 01:11 PM |
Was going to post this up as-well
you beat me to it
Crazy money ....
wylliezx9r
posted on 17/2/12 at 01:13 PM |
How did that old song go ........ Dreaaaaaaaaaaam dream dream dream .......what a joker.
George Best
RK
posted on 17/2/12 at 01:20 PM |
But it's 90% complete!
steve m
posted on 17/2/12 at 01:23 PM |
In the pics, its not!
fesycresy
posted on 17/2/12 at 01:26 PM |
I chuckled when I saw it too......
There's also this one who's trying to mislead people with the title, then gets p1ssed when he has emails!
Westfield Kit Car, Project Car, Kit car, Westfield se kit car | eBay
clanger
posted on 17/2/12 at 03:25 PM |
What about the worlds fugliest Striker for a bargin £16K.............spend the extra £2K on getting the body sorted back to normal
FUGLY Striker
posted on 17/2/12 at 03:46 PM |
Hells teeth, what a death trap If you wanted to design a front and rear suspension that would fail prematurely and catastrophically I don't
think you could do much better than that. Easily one of the worst examples I have seen; no one showing that level of engineering ignorance should be
allowed to pick up a welder.
What on earth is a "Zetec Red top" as well?
Thank god for the IVA, I'd hate to think of this getting on the road without a complete re-design.
[Edited on 17/2/12 by MikeRJ]
andyace
posted on 17/2/12 at 03:57 PM |
Sent the guy an email asking about the pics as he says its 90% complete, and also about the price :
REPLY:
The pic are just wot I had on me phone as I'm off shore I will up date them when I'm back if you look in to the spec of the engine and
turbo and the turbo busa kit car start from 20 k and that only for a 220 bhp this will do 450 no sweat out els you won't to no give me a
shout
- supersug
Proby
posted on 17/2/12 at 04:30 PM |
Sweet motor and blower, but Jesus Christ! £18K he's having a larf!
jacko
posted on 17/2/12 at 04:37 PM |
eBay - The UK's Online Marketplace
Would this fit the chassis he is selling ? that will be the body sorted
Jacko
wilkingj
posted on 17/2/12 at 04:59 PM |
I like the Herringbone floor in the Batman car.. rather unusual
Best Regards
Geoff
http://www.v8viento.co.uk
Slimy38
posted on 17/2/12 at 05:50 PM |
Erm, ok, I thought that was just a bit expensive for a finished car...didn't realise that it was 18k for an engine and some bits!!
Slimy38
posted on 17/2/12 at 06:10 PM |
quote: Originally posted by MikeRJHells teeth, what a death trap If you wanted to design a front and rear suspension that would fail
prematurely and catastrophically I don't think you could do much better than that. Easily one of the worst examples I have seen; no one showing
that level of engineering ignorance should be allowed to pick up a welder.
I have to admit, I have zero engineering knowledge, but I can see several problems. Could you tell me if I'm the right track, I'd
appreciate knowing what 'not to do' when it comes to doing my car?
Rear suspension arms too narrow for the length.
I can't see what would prevent the rear upright from rotating, given that the bottom arms aren't connected?
Rear damper only acting on one bottom arm, I think that would actually encourage suspension rotation!
Far too weak front damper fixing on the bottom.
The Y shape rear top arm and the pentagon shape front top arm?
That steering rack looks really odd.
Hugh_
posted on 17/2/12 at 06:44 PM |
I spotted the following, but have no real engineering experience either :/
Front
- Shock mount rod not substantial enough
- Shock mount rod to wishbone connection not reinforced
- Wishbone end plate (where balljoint sites) not adequately joined to wishbone arms
- Weak point where the wishbone arm tapers to the flat bit at the end
- Top wishbone looks like its been bent rather than cut and welded, so will be a weak point.
Rear
- Yes wishbones are too narrow
- Wishbones are unequal length so bump will change toe out (not the end of world, but not ideal)
- 4 tube nature of top wishbone isnt ideal
- Bottom wishbone single diagonal better than nothing, but one going to other way would prevent rotation.
- Hubs sit an awfully long way out of the chassis, wheels will protrude bodywork.
- Diff carrier doesn't support rear of diff adequately (missing bolt bottom right)
posted on 17/2/12 at 06:53 PM |
Someone's not judging the market very well!
It's Evolution Baby!
posted on 19/2/12 at 01:31 PM |
Yes, and the upper arms are a very weak design with no triangulation.
Forces from braking will try to rotate the upright, and because the spring/damper mounting is to one side of the upright, vertical forces through the
tyre/wheel will try to make the upright rotate around this point. Normally neither of these would be a problem since with three rigid mountings the
upright should be perfectly able to resist this. However, with an upper "wishbone" that has the rigidity of a piper cleaner then things
are likely to bend/fatigue very quickly.
The damper mounting on the lower rear wishbone looks like a prime failure point, you are loading a slender tube in bending, the force is being applied
to a single point on the tube rather than spread out and that point has been welded, weakening the tube.
This was a weak point of the original book arms, but this builder has almost certainly made them even weaker by drilling holes through the tubes to
support the bottom of the shock.
Clearly little understanding of the concept of "triangulation". The rear chassis bracket for the front top wishbone also appears to be
badly supported, but this might just b the angle of the photo.
Hard to see but the rack mountings look a bit flimsy, and the whole rack is mounted much further back than I'd expect. The builder might have
done this in order to dial out some bump steer however.
Slimy38
posted on 19/2/12 at 02:11 PM |
Thanks Mike, sounds like I'd spotted some of the biggies. The steering rack looked too far back to me, I'd not even noticed the fixing!
Liam
posted on 19/2/12 at 06:43 PM |
Crikey that suspension is an abortion!!
As well as everything pointed out already, just look at the suspension geometry. Looks like both ends, especially the front, have the wishbones
further apart (vertically) inboard than outboard, so camber gain in bump/droop will basically be the wrong way round! Just look at how high up the
chassis the front upper brackets are fitted compared to where they normally go, for example.
Buyer, if there is one, needs a warning certificate.
