mark chandler
posted on 3/4/12 at 05:34 PM |
Two stroke oil in a diesel engine
Was googling around as bored the other day and came across a diesel forum where they were recommending adding a little 2 stroke oil to diesel when
filling up.
They do this as modern diesel has almost all sulphur removed so lubrication is down, it's also claimed to improve power and generally be a good
thing.
My V40 has 150k miles on it so I thought I would give it a go, £10 splashed on quality synth castrol 2 stroke oil, filled it up with a fresh tank of
diesel and tipped in 250ml.
The car is definitely faster, quieter and smoother... also seems to smoke a little less, all the things they claim.
I am worried about the HP pump or injectors failing as the car becomes scrap really, if it lubricates this lot and keeps it going for longer then I
will be happy, anyone else do this?
For me it’s worth a punt.
Regards Mark
owelly
posted on 3/4/12 at 05:40 PM |
For me, you've just wasted 250ml of expensive 2-stroke oil. But like religion, if it makes you happy.....
http://www.ppcmag.co.uk
Canada EH!
posted on 3/4/12 at 05:43 PM |
Two stroke oil does wonders for the performnce of mazda RX engines as well.
dlatch
posted on 3/4/12 at 05:56 PM |
i can see it doing only good things but save cash and use regular 2 stroke oil no need of the good stuff imo
The Shootist
posted on 3/4/12 at 06:09 PM |
Pretty comon on highly modded pumps..
High volume pump modders often do add 2 stroke oil. It's pretty common with the VW rotary pump guys who run 13 and 14mm pump heads as they tend
to seize at high revs.
Bio diesel also makes significant improvements to lubricity. According to Bosch they scratch test equipment shows that 5% bio improves lubricity
higher than most any aftermarket diesel additives do.
Their tests actually found the Lucas additives to decrease lubricity.
l0rd
posted on 3/4/12 at 06:49 PM |
Dunno but we use 2 stroke oil in the tractor as it lubricates the pump and saves us hundrends of £ for a new one.
one bottle on every other fill up
dinosaurjuice
posted on 3/4/12 at 09:26 PM |
proper EN spec biodizzle is lovely stuff. dinosaur friendly too.
posted on 3/4/12 at 09:27 PM |
Do you have a link to the diesel forum Mark?
mark chandler
posted on 3/4/12 at 10:40 PM |
I think this is it
linky dink
Regards Mark
hughpinder
posted on 4/4/12 at 07:23 AM |
I've heard its what naughty people add to heating oil (28 second kerosene is similar octane rating to diesel, hence all the 'not to be
used as automotive fuel' warning on every invoice) to give it some lubricity, as that the main problem using it. As someone else said, veg oil
is supposed to be as good or better, and is cheaper, but can strip the crud out of your fuel tank and block the fuel filter when you first use it.
Regards
Hugh
