Author: Subject: using XJS temp gauge with pinto engine
kp
posted on 19/4/12 at 02:46 PM Reply With Quote
I liberated nice temperature and fuel gauges from a scrapped Jag XJ12. Any ideas how to hook up to temp gauge to the temperature sender.
I've experimented with a couple of configurations, but I either get no movement or the needle goes over to the far right.
Do I need to put in a resistor or something? Or can I get a sender which will "drive" this gauge correctly?
If it helps, the brass spade connector has at '+' symbol embossed on the plastic beside it.
Images below...
http://www.flickr.com/photos/kenpower/7093496169/
http://www.flickr.com/photos/kenpower/7093495933/
[Edited on 19/4/12 by kp]
kp
posted on 19/4/12 at 05:18 PM Reply With Quote
Update
I have (unscientifically) recorded the response from the pinto water temp sender. The results on a googlg chart are here.
https://docs.google.com/spreadsheet/ccc?key=0Ap3oHWKOOjAEdHVJU3dBVS01d3B6eTBlX3E4Y3dVQlE
This might help someone figure out how I should connect the gauge.
