New Topic New Reply
Author: Subject: Tyre pressures
Mikey G
posted on 30/8/04 at 12:18 PM Reply With Quote
Tyre pressures
Need to check my tyre pressures and not sure what i should run them at?
Car is Stuart Taylor fireblade with 175/60 13 Yoko A539's for road use.
Currently all about 21psi since i had it and i feel i need to go up slightly.
Mike
Wadders
posted on 30/8/04 at 01:19 PM Reply With Quote
I run mine at 16psi all round (cold). 21 sounds a bit high for such a light car, i sometimes bump the rears up to 18 if i'm carrying a passenger. As the tyres warm up the psi rises, check them after a hard blast, they may have gained 4 or 5 psi.
i]Originally posted by Mikey G
Mike
Jasper
posted on 30/8/04 at 01:20 PM Reply With Quote
Yup - also run 15-16psi.... plenty.
Mikey G
posted on 30/8/04 at 07:07 PM Reply With Quote
I'll check them again when cold as 21 was after a little run.
It just feels like its rolling over on the tread on the rear and the sidewalls are looking a little scrubbed.
Mike
Jasper
posted on 31/8/04 at 11:39 AM Reply With Quote
Stop rubbing the curbs then
New Topic New Reply
