New Topic New Reply
Author: Subject: Check your nuts!
James
posted on 24/5/12 at 12:51 AM Reply With Quote
Check your nuts!
No, not them.
Well, ok, you should be checking them as well I spose.! Once a month, whilst relaxed in a warm bath I believe!
Anyway, I digress.
I've had problems with my rear wheels hitting the rear GTS wings. I've ground away the return on the wing so hopefully it's okay now. But just to check, decided to removed the wheel, the shocker, re-fit the wing and see if it still hits.
Found to my horror the calliper moved easily by hand. Turns out the 2 bolts that fix the calliper carrier to the Sierra hub were very loose.
Was late for training so didn't diagnose further. No idea if I loctited it when I built 6 years ago.
Anyway, moral of the story is: check you nuts (and bolts!) and loctite them**!
James
**And there, I DEFINATELY mean the ones on your car!
[Edited on 24/5/12 by James]
bartonp
posted on 24/5/12 at 07:41 AM Reply With Quote
Seems to be a common theme here with many threads past....
johnemms
posted on 24/5/12 at 07:49 AM Reply With Quote
With reference to the wheels hitting the arches..
Would putting an extra bump stop inside the coilovers to limit travel work for you?
Just a thought..
cheers
jon
wilkingj
posted on 24/5/12 at 08:02 AM Reply With Quote
Caliper bolts benefit from a dob of locktite on them.
Conside the amount of vibration they get on braking. OK its not wild vibration. However, its high frequency vibration, and can still loosen bolts over time.
Just my 2d's worth.
Best Regards
Geoff
http://www.v8viento.co.uk
bartonp
posted on 24/5/12 at 09:21 AM Reply With Quote
Just my 2d's worth.
Sure do - look here:
http://www.flickandshare.com/l/WTSWBW
daviep
posted on 24/5/12 at 09:30 AM Reply With Quote
Just my 2d's worth.
I would happily disagree with that, in 15 years I've never loctited a caliper bolt or had any come slack, copper grease all the way for me.
Davie
New Topic New Reply
