nib1980
| posted on 4/9/12 at 06:47 AM |
Photo results - crappy week
Hi guys,
heres the end results of the crappy week.
  failure 1
  failure 2
  failure 3
  failure 4
designer
| posted on 4/9/12 at 07:32 AM |
That wishbone should be a heavier gauge.
MRLuke
| posted on 4/9/12 at 10:59 AM |
Depends on whether you would rather be replacing wishbones or doing chassis repairs really
Hopefully wont be long before you are back on the road
[Edited on 4/9/12 by MRLuke]
sa-fabrication
| posted on 4/9/12 at 11:34 AM |
I made a similar wishbone last week and noticed immidiatley that this would be an issue.
I am going to develop a better and stronger set of wishbones.
Just out of interest, did you hit anything? or did they just fail under cornering?
Ive noticed quite a few faliures in that area of the wishbone design.
nib1980
| posted on 4/9/12 at 11:41 AM |
Bbeen fine for 6 years then went under braking.... Thankfully in a straight line
nib1980
| posted on 4/9/12 at 11:42 AM |
bartonp
| posted on 4/9/12 at 01:17 PM |
Looks like it's gone right where you'd expect - as the mounting plate finishes, and the heat affected zone from the weld (MIG?) meets the
virgin tube. Quite a good case for brazing there, if you want to make it that slim....
designer
| posted on 4/9/12 at 02:33 PM |
Don't think you are allowed to braze road cars, even if racers do it.
myke pocock
| posted on 4/9/12 at 06:35 PM |
Certainly LOOKS thinner wall than that I used. Did you make them yourself or buy them? Is it ERW or seamless? BTW designer, why can you not braze a
chassis for the road?
| posted on 4/9/12 at 06:56 PM |
Caterhams are brazed (or used to be, anyway).
The main thing is that they are bronze-brazed (copper + tin) - very strong - rather than brass-brazed (copper + zinc) - rather brittle.
nib1980
| posted on 4/9/12 at 07:14 PM |
mope bought in parts when i got the kit
| posted on 5/9/12 at 02:06 PM |
That wishbone should be properly designed rather than just making a flawed design heavier. The GTS style wishbones have a fraction of the bending
moment (in both planes) that this one does, and is probably lighter.
40inches
| posted on 5/9/12 at 02:47 PM |
Same design as these would be much better haynes roadster FRONT WISHBONE set locost 7 kitcar | eBay
nib1980
| posted on 5/9/12 at 02:56 PM |
Any idea how I can check dimension and that they fit cortina hubs
40inches
| posted on 5/9/12 at 03:00 PM |
Contact details, never hurts to ask
Phil Eagle
4 Ascot Mews
Southminster
Essex
CM0 7GH
United Kingdom
Phone: 07940708360
Email: talonmotorfabrication@gmail.com
bartonp
| posted on 5/9/12 at 03:12 PM |
If your name's 'Lotus' you can glue it if you want to.
Phil.
austin man
| posted on 5/9/12 at 05:09 PM |
Mine bent at that point I believe due to using a zetec rather than the lighter Kent engine which the locost idea originally housed. MK mas me some in
Flat oval bar never had a problem after that
Minicooper
| posted on 5/9/12 at 08:04 PM |
No idea if they will fit or not, but I have pair of lower haynes roadster wishbones manufactured by 3GE, £60.
If you provide your dimensions I can compare them to my wishbones to see if they are compatible
Minicooper
| posted on 5/9/12 at 08:07 PM |
Mike,
What makes the gts wishbones have a lower bending moment? Just trying to understand the difference between the original wishbone
Not Anumber
| posted on 28/11/12 at 08:42 AM |
who made the original wishbones that broke ?
mcerd1
| posted on 28/11/12 at 01:14 PM |
I'm led to believe TIG welding is another option, but for a locost solution a heavier gauge tube or a better design around the welds would be
easier
[Edited on 28/11/2012 by mcerd1]
coyoteboy
| posted on 28/11/12 at 01:36 PM |
I've never seen anything that suggested that any form of connecting parts was illegal, other than to suggest that it should be secure and strong
enough. No reason not to glue parts if you can do it in a controlled and safe way.
designer
| posted on 28/11/12 at 02:10 PM |
Most IVA inspectors do not like brazing as you cannot guarantee what rod you have used and, above all, who has done it. Welding is prefered as it is
easier for an amateur and easier to judge the quality by the look.
coyoteboy
| posted on 28/11/12 at 09:57 PM |
But does it specify anywhere that you can't? I think they'd have a hard job arguing it really, in the same way they can't see who
made it and how, the same applies to a whole heap of stuff - at what point do you stop - is your flywheel lightened? If so, how do they know it
won't explode - who did it and how?
skodaman
| posted on 29/11/12 at 12:18 AM |
I've had a car fail mot because of brazed sills and that was over 25 years ago so I'd presume it's not allowed on anything
structural even if various racing machines have used it.
Skodaman
