New Topic New Reply
Author: Subject: I don't beieeeeve it!
posted on 19/9/04 at 02:57 PM Reply With Quote
[Victor Meldrew mode on]
I've been working on my engine, trying to raise some oil pressure, and yesterday I put it back in the car to see if I've fixed it.
Guess what - the starter's inertia gear seized! Aaargh! It's a conspiracy, I tell you...
Now I've got to make a spring compressor, so I can strip the starter's inertia gear, sort out what I find, rebuild it, THEN see if I can raise any oil pressure...
A black cat must have crossed my path, or I gave some witch an earful of abuse, or something...
Everything else on the car is ready for the SVA - b*ggerit.
I was so pee'd off this afternoon that I went out and heaved old plants out of the fishpond - that's how desperate I was!
rgds,
posted on 19/9/04 at 03:46 PM Reply With Quote
Is that a dead Robin I can see on your offside nosecone?
Good luck with it!
posted on 19/9/04 at 05:36 PM Reply With Quote
David do you mean a starter bendix spring compressor?? I may have one you can borrow if I can find it ,but i'm in Cambridge . You may not need to remove bendix if it is just sticking, try WD 40 and working bendix manually, worth a try. Rusty
posted on 19/9/04 at 06:44 PM Reply With Quote
Rusty,
It's been sort of sticking for a while, but now it's seized completely.
I'll try the WD40, otherwise I'll have to make a compressor on the lathe (not difficult, just 2 big 'washer-shapes' and some screws). It's just another time-waster.
[Edited on 19/9/04 by David Jenkins]
posted on 19/9/04 at 06:51 PM Reply With Quote
Don't use WD, it's fatal.
Try dipping it in petrol, bendix should never be lubricated or they get caked up in clutch dust and stick even more. Petrol cleans stuff out and then evaporates.
[Edited on 19/9/04 by Peteff]
posted on 19/9/04 at 08:02 PM Reply With Quote
petrol will not lubricate bendix , use WD 40 to free it off , then dry it off . Seem to remember graphite from pencil lead is a good lubricant for a bendix. Rusty
posted on 19/9/04 at 08:05 PM Reply With Quote
Tried brake cleaner spray - similar effect to petrol, and evaporates rapidly. Also tried lock graphite.
Neither worked.
I think it's something catching inside the moving bit, where the return spring lives.
DJ
New Topic New Reply
