Author: Subject: Help needed cycle wing brackets
olimarler
posted on 13/1/13 at 09:11 PM Reply With Quote
Hi all!
Managed to snap cycle wing bracket right near the top.
Removed the bolts holding it on and the arches bolt
But the arches are bonded on. Any ideas how to remove the bonding so I can re weld it?! As the break is right next to arch.
Help
Oli
umgrybab
posted on 13/1/13 at 09:37 PM Reply With Quote
You can usually debond thing like these by getting a Stanley knife and cutting along the join. You will most likely need to trace the cut several times to fully release the wing. It may help to use a utility knife with the long, snap off blades as these can usually flex under the metal and cut deeper.
olimarler
posted on 13/1/13 at 09:47 PM Reply With Quote
Cheers I will give it a go.
Lets hope it's not got to much on there!
Oli
big_wasa
posted on 13/1/13 at 10:36 PM Reply With Quote
Something like a cheese wire and a sawing action does the job. I have used thick fishing line before.
posted on 14/1/13 at 07:32 PM Reply With Quote
Have a word with your local windscreen fitter, he may let you have a length on screen removing wire
