Author: Subject: FS: 6 ETB Gauges and Bright 6 display
Worzey
posted on 23/4/13 at 08:41 AM Reply With Quote
As a result of an upgrade to a DD2 I've got a set of 6 ETB gauges plus a Bright 6 for sale.
The ETB gauges are black on white with 80mm Speedo and Tacho with Water, Volts, Fuel and Oil. No senders as they where re-used on the DD2 install.
They retail for over £400 plus P&P new. Looking for around £250 including P&P. Offers before they go on ebay?
Caterham R400
Sellsie
posted on 23/4/13 at 02:18 PM Reply With Quote
Could you tell me if the Rev counter can be reset to work off a six cylinder engine and can the speedo be reset for alternative senders.
If the answer is yes to both questions I will have the set please.
Worzey
posted on 23/4/13 at 02:29 PM Reply With Quote
Sellsie, The speedo is programmable but I believe the 80mm tacho's are built for specific engine configurations. In this case a 4 cylinder engine
I don't think you'll be able to use it.
Caterham R400
Sellsie
posted on 23/4/13 at 03:55 PM Reply With Quote
Worzey
Thanks for the quick reply.
As the rev counter will not work on a Six cylinder I will give it a miss this time round.
Good luck with the sale I hope some other deserving Locoster grabs the bargin.
Sellsie
