New Topic New Reply
Author: Subject: Driving an unregistered car
pekwah1
posted on 25/4/13 at 01:23 PM Reply With Quote
Hi guys,
So have had some conflicting information from VOSA.
I was asking if i can drive my unregistered kit to a garage to get some welding done (chassis plate) before the IVA assuming that i am insured.
On the phone they said yes, but when i emailed (wanted confirmation in writing for when i get stopped by the plod) they have said no. They have said that i can drive it after IVA however when i need to get work done after a failure.
Any thoughts?
Regards,
Ben_Copeland
posted on 25/4/13 at 01:30 PM Reply With Quote
You can drive it to mot or place for repairs are carried out as long as its insured on the chassis number
Ben
Locost Map on Google Maps
Enter Your Details Here
twybrow
posted on 25/4/13 at 01:46 PM Reply With Quote
I understood it that you could drive it to the IVA, and then any place afterwards to have repairs done to pass the IVA. But before the IVA, you cannot drive it on the road. I had this in writing from VOSA as I too was worried about being stopped.
blakep82
posted on 25/4/13 at 01:48 PM Reply With Quote
Both half right, as I understand it.
YOu can drive to get remedial/repair work done, that is to say, it has to have failed a test before its remedial or repair work
So, for what you want to do, no. But if you fail iva, and need a garage to fix something, then you can drive to a booked garage
________________________
snapper
posted on 25/4/13 at 02:05 PM Reply With Quote
I think DVLA are the more appropriate government department to ask these questions of
I eat to survive
I drink to forget
adithorp
posted on 25/4/13 at 02:22 PM Reply With Quote
PMSL... They might be the people to ask but you'll get a different (and usually wrong) answer every time
The rules are, You can drive to/from a pre-booked and required test (IVA) and to/from a place of repair for remedial work required due to failing that test.
So to/from IVA... yes.
To/from repair garage once it fails IVA... yes.
For an MOT... no
To DVLA inspection... no.
To garage to weld vin plate before IVA... no
http://jpsc.org.uk/forum/
jollygreengiant
posted on 25/4/13 at 03:05 PM Reply With Quote
I think that, until the law/legal position changes, that THIS thread ought to be made a sticky, because of the number of times it gets asked and (MOSTLY) because this is once of the quickest, easiest and most succinct answers that I have seen.
Just my 2p's worth.
whitestu
posted on 25/4/13 at 04:17 PM Reply With Quote
I should think that depends on what the remedial work is.
Stu
renetom
posted on 25/4/13 at 04:42 PM Reply With Quote
Hi
No you cannot drive it anywhere prior to IVA.
I know a guy who could probably come to you & do the welding.
He's in Horley.
Give me a ring if you wish
René 07831 42 21 59
only up the road.
failing that I have a trailer.
ReMan
posted on 25/4/13 at 04:51 PM Reply With Quote
No I could'nt work ouit if this was a serious answer or not
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
designer
posted on 25/4/13 at 06:17 PM Reply With Quote
Just pop rivet it on.
ashg
posted on 25/4/13 at 10:21 PM Reply With Quote
vosa as an agency are 1000x more organised than dvla, and actually do know what they are talking about!
you can drive it to the IVA or any ministry of transport approved test. if it fails that test you are then permitted to drive it to a place for remedial work. you cannot drive it prior to the test!
so you can drive it to an iva or an mot after that you can drive it to a garage to have the faults fixed thats it. technically failing the test driving it home then a couple of days later driving it to a garage is technically pushing it but its generally not a problem unless you get pulled by a real jobs worth.
btw a vosa inspector has the similar powers to a police officer to take a vehicle off the road.
[Edited on 25/4/2013 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
posted on 30/4/13 at 07:42 PM Reply With Quote
a set of alphnumeric punches from Machine Mart and stamp the number on = job done - why make it more difficult than it needs to be?
there was talk from way back that the VIN needs to be permanent;y attached so rivetsd and screws are a no-no.
New Topic New Reply
