New Topic New Reply
Author: Subject: Headlight support bracket dimensions
Padstar
posted on 1/6/13 at 01:43 PM Reply With Quote
How long should the headlight support brackets be?
theduck
posted on 1/6/13 at 02:48 PM Reply With Quote
For what car?
Padstar
posted on 1/6/13 at 03:40 PM Reply With Quote
Sorry haynes roadster. It doesn't seem to show a dimension in the book
Hopley89
posted on 1/6/13 at 04:18 PM Reply With Quote
i built mine at what ever size i wanted to .. i just made two the same and for the threaded stud i used a 3mm washer and welded it in the center ..
40inches
posted on 1/6/13 at 05:04 PM Reply With Quote
My MK is 140mm from chassis to centre of headlamp mounting hole, and centred on the top shock mount.
MK should be the same as the roadster in plan.
Padstar
posted on 1/6/13 at 05:13 PM Reply With Quote
Thanks guys. The roadster book also says to center on the shock mount so i will use the 140mm mentioned and go with that. Have you threaded the lighting cable through the oval bracket or cable tied it to the underside of the headlight mount?
40inches
posted on 1/6/13 at 05:26 PM Reply With Quote
I did neither, I used stainless shower hose, leading to a grommet in the side panel. The hose has a teflon-ish liner inside, and cost about £3 from Lidl.
You can just about see it on the left side of this photo.
New Topic New Reply
