ashtal
posted on 31/7/13 at 07:14 PM |
Semi spaceframe in a mk1 Astra, will it need sva?
I'm converting my mk1 Astra into rwd using 200sx running gear.
This is my first mock up of the rear spaceframe section to give you an idea of my plan.
I want to know if I can complete the car and just mot the car or will it need an sva test?
imp paul
posted on 31/7/13 at 07:37 PM |
should be fine zcars do this all the time with no sva hope this helps
stevebubs
posted on 31/7/13 at 08:42 PM |
strictly speaking, yes...as you're altering the chassis....
Slimy38
posted on 31/7/13 at 09:14 PM |
I have wondered about some of their work though, their mini bodies over spaceframe chassis seem a significant enough change to warrant an iva. But as
you say they seem to avoid it.
matt_claydon
posted on 31/7/13 at 09:54 PM |
That's because nobody checks though. This can be a grey area, but significant chassis mods, particularly combined with engine, drivetrain and
suspension alterations would definitely constitute a 'radically altered vehicle' and therefore require IVA. However, because the MOT
tester will probably go with the 'looks like a mini - is a mini' approach, and wouldn't actually know whether it had been IVAd or
not, this kind of thing goes unnoticed until you have a nasty accident
posted on 31/7/13 at 10:11 PM |
I would say it would need an IVA. A spaceframe alone would too, seeing as its a significant modification to the chassis, but changing it to RWD is
well into 'radically altered' territory.
Didnt zcars have some bother about this a few years back?
ashtal
posted on 31/7/13 at 10:34 PM |
Iva it is then! That will put a few quid on the build cost. Is there a check list for iva?
Slimy38
posted on 1/8/13 at 05:34 AM |
The downloadable IVA manual is your best bet, although as long as you keep the outer shelf as Vauxhall intended you'll already be halfway there.
With exterior protrusions being a common failure point, you'll just avoid the issue completely!
blakep82
posted on 1/8/13 at 08:34 AM |
Link for the manual below
Yeah, to make it rwd, you'll almost definitely need to cut out sections of the floor (bigger tunnel for a front engined car, boot floor for a
rear engine) so 100% 'should' be iva'd
________________________
