Autoflock Motorsport
| posted on 5/5/15 at 09:59 AM |
My car trasporter trailer project with pics
Well I managed to get a bare trailer chassis off a user on here ho lived not far from me. A lot of stuff was included with the trailer so it only
needed bolting together and a few lights, brakes, ramps etc adding. Here is how I got on:
sorting the brakes and preparing the lights
Light mounting plates welded on
now to sort and the drums
Had to remove the hitch to re arrange the brake compensator mechanism
Compensator done
Lick of paint with help from her in doors
Folded some cheq plate to make the ramps
Some more steel
Ramps storage
Lights starting to work
All done
Kind regards
Raj
http://www.locostbuilders.co.uk/forum/23/viewthread.php?tid=183445
907
| posted on 5/5/15 at 04:10 PM |
This is intended as helpful advice, and not as criticism. I do hope that you take it as it is intended.
Hi.
When a car sits on a trailer all the weight is on the front and the back, and the strain is in the centre. Think see saw.
The chassis needs to be deeper and stronger in the middle so the trailer doesn't break its back. My Alko chassis does
just this, in fact that's why there are chassis mount holes in your axles that you haven't used.
IMHO you should either add an inverted angle, tapered off to nothing at the front & back; or, add 3 smaller angles
bolted to the axle plates and bolted or welded to the main angle at the front & back. ( see pic )
Possibly add short upright joiners.
This mod IMHO will double the strength of the trailer for little extra weight.
Paul G
dubstar_04
| posted on 6/5/15 at 06:47 AM |
Hi.
Paul G
Paul,
You are absolutely correct and I spent quite a while designing the trailer and ran through a few different designs. What you see here was the most
simple construction that I came up with and i did calculations to verify the loading on the sections in order to get rid of the extra bracing.
Its not perfect by any means but it is however fit for purpose, just avoid pot holes!!!
With that in mind there is absolutely no problem adding the bracing in at a later date if there is a little creep.
[Edited on 6/5/15 by dubstar_04]
adampage
| posted on 6/5/15 at 07:28 AM |
It'll be fine if I avoid potholes?!
Now that's a scary way to drive a trailer.....
Bit tough to swerve to avoid a pothole with a loaded trailer!
I'd just add the strengthening rather than drive constantly thinking it'll be fine if I miss the potholes, but each to their own I
guess....
Good luck!
Ad
| posted on 6/5/15 at 07:30 AM |
Hi.
Paul G
Thats very helpful, will be adding in some steel as per your drawing over the next few weeks time permitting.
Kind regards
Raj
907
| posted on 6/5/15 at 07:46 AM |
If it helps, a pic of my Alko bare chassis.
I borrowed the wheels just to get it home. Now fitted with 10 x 185's.
My axles look very similar to yours.
Paul G
  Transport wheels only
| posted on 6/5/15 at 08:32 AM |
cheers paul
Kind regards
Raj
