olberj
| posted on 26/7/15 at 02:54 PM |
Seraph Bonito
Wasn't sure where to put it but this is the latest project :
Front engined, mounts for rover v8, axle, prop and brakes etc already there Ford items I believe.
Thought it had potential so picked it up cheap and wondering what to do with it now.
Anyone familiar with them?
| posted on 26/7/15 at 03:31 PM |
Forget the Rover lump, fit a Lexus V8?
slingshot2000
| posted on 26/7/15 at 04:00 PM |
I don't think I have ever seen one of those before. It has lots of hints of a Ford GT40, but front engine, to me !
I agree with Rusty though, a modern quad-cam V8 would suit it .
Is it a space frame ?
Regards
Jon
olberj
| posted on 26/7/15 at 07:56 PM |
It does indeed have a space frame. Old ft bonitos were Beetle based.
What gearbox are folk using with the uzfes these days, still Supra boxes?
It's got the prop shaft for the rover box there already.
Volvorsport
| posted on 26/7/15 at 11:15 PM |
think these were made in lincolnshire at one point , cortina based ....not sure tho..
www.dbsmotorsport.co.uk
getting dirty under a bus
olberj
| posted on 26/8/15 at 10:32 PM |
Got the car over to my storage place and got a good look around it. Have been thinking about engines etc and what to pick to give it a suitable
soundtrack and performance figures to match. Here's the chassis itself :
So it's Ford Cortina running gear and the engine bay is set up for a Rover V8. I was thinking of using the Lexus LS400 V8 and a BMW Getrag box
as the parts are so readily available. Looking at it today though, well it looks like it should be mid engined, no?
I'm also acutely aware that there is absolutely no roll over protection should the worst happen. It really needs a cage.
So if going down that route, why not incorporate a rear engine cradle and use the Audi box i have lying around mated to a 4.2V8?
It's obviously more work but it's worth doing right i think. Anyone any good with cad?
Here's how Ultima do it :
Some new tubing for cage and cradle isn't too daunting but i'm not 100% on the rear suspension. It's basic Ford Cortina stuff with
coilovers added at the moment so anything will be an upgrade. Diff etc would obviously be swapped out completely for Audi hubs, shafts and whatnot.
Go all out and do it properly or fire in a V8 to the front and take it drag racing. Thoughts?
Irony
| posted on 27/8/15 at 07:42 AM |
Looks like you would have to butcher the chassis to make it midengined. I would go with the 1uzfe.
Ugg10
| posted on 31/8/15 at 08:14 PM |
http://www.pistonheads.com/gassing/topic.asp?h=0&f=30&t=1121843&mid=0&nmt=S1+Elise+kit-car
Link at the bottom of an elise based version for sale may be of interest.
[Edited on 31/8/15 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
olberj
| posted on 31/8/15 at 08:43 PM |
Nice one. Looks like the Avenger kit.
olberj
| posted on 19/11/15 at 09:59 PM |
Decided to go for the Audi route in the end. Bought an a4 2.5tdi and wrenched the gearbox out.
Here's the A8 I've started removing the engine from.
Will be mid mounted, modifying the chassis to fit.
Any suggestions for wishbone set ups to use? The A8 suspension isn't going to be a suitable swap i don't think. Too comfort biased.
ettore bugatti
| posted on 20/11/15 at 09:00 PM |
I would keep it simple as possible. Cortina uprights front with Sierra hubs at the rear combined with tubular wishbones.
But going all this effort, isn't an idea to build a GT40 replica instead?
Nickp
| posted on 21/11/15 at 08:11 AM |
Seems mad to me to go mid mounted with a chassis that's clearly designed to be front engined. You'll be chopping away that much that you
may aswell throw it away and start again I'd stick that great Audi V8 up front with a RWD box but convert the rear to IRS. Just my opinion
and it looks like a cracking bodyshell that should be stunning once done
[Edited on 21/11/15 by Nickp]
olberj
| posted on 1/6/16 at 09:44 PM |
Best update this then.
Went through a whole wad of ideas and then my mate wanted to move on his Mk2 mr2 so I sent up the old man to drive it back from Drumnadrochit.
Didn't miss a beat. £200 well spent.
Anyways once back in the unit I parked it up next to the Bonito and was shocked on the sizes. The wheelbase isn't just close, it's exactly
the same.
The idea was to use the Mr2 as a mule for the v8 and then swap all the parts into the Bonito chassis. Building suspension pick up points is not so
easy, not to mention windscreens, wipers, demisting, etc etc so why not rebody the Mr2?
I don't plan on bonding anything that might rust underneath. Flip up front and engine cover section. Reuse as much of the Mr2 as possible.
Extensive roll cage. Lots of off the shelf parts available too, upgrades etc. Makes sense that way.
So take one mr2 t bar and get the grinder out.
I'll move the firewall forward and build a cradle for the engine and box so that whole unit goes in and out from underneath with the rear
suspension attached.
olberj
| posted on 1/6/16 at 09:46 PM |
Another fairly major bit of progress today. It fits! Well, we made it fit.
Can actually roll it about with the engine in now. Much fun.
Doors also open and shut as before. Phew!
[Edited on 1/6/16 by olberj]
