Dick Axtell
| posted on 14/12/04 at 08:50 AM |
CAD Tutorials - FAO ChrisS!
This web page will be of interest to anyone (like me) who needs AutoCAD guidance.
www.llpsite.com/tutor.htm
Lol
ChrisS
| posted on 14/12/04 at 01:44 PM |
Perfecting my AutoCAD Skills, thought id redesign a book dimension bottom wishbone to utilise a more common design and with bush tubes suitable for
polybushes.
What do you think?
  Redesigned Book Bottom Bone
[Edited on 14/12/04 by ChrisS]
Volvorsport
| posted on 14/12/04 at 01:51 PM |
yeah thast good - now get the mount for the shock absorber as close
to the ball joint as possible
www.dbsmotorsport.co.uk
getting dirty under a bus
ChrisS
| posted on 14/12/04 at 02:06 PM |
Other than the length of the shock absorber dictating wher the shock mount goes, whats the significance of it going as close to the ball joint as
possible ?
Volvorsport
| posted on 14/12/04 at 02:15 PM |
its stronger , theres less leverage on the mounting point - ive seen a really good idea - i think it was on a swedish built car - IMHO , although im
not commenting on designs , this is the point which causes failures or bending because the bottom wishbone is loaded unevenly
this is the link
http://www.mhk.lu.se/home/staffanl/min%20seven/2002-01-08/MVC-305F.html
[Edited on 14/12/04 by Volvorsport]
Dick Axtell
| posted on 14/12/04 at 06:40 PM |
Hi Chris,
Suggest you make the wishbone arm tubing larger in dia. Luego have upgraded to 25mm dia.
The Aussies appear to have similar web plate, but welded to upper centre-line of wish bone tubing.
See attached example.
ChrisS
| posted on 14/12/04 at 08:07 PM |
Dick
Although it might not look like it, but i have upgraded the main tubes to 25mm x 2mm wall thickness, it might not look like because ive also upgraded
the bush tube sizes to incorporate a polybush as well, or were you suggesting a thicker wall thickness as well?
Cheers.
PS i may not make these for my self its really just an exercise in producing the wishbones to see how accurate i can make them.
