MadMaxx
posted on 9/4/16 at 02:21 PM |
Sierra diff upper long bolt
Hi, where I can find the Sierra diff long bolt M12 x 208 mm?
The only site that seems to sell it is this one:
Cosworth Rear Diff / Beam long bolt - new
even if there isn't any technical description to confirm it is the proper one, but it doesn't ship abroad
Maxx
My re-building diary:
http://www.llcc.it/YetAnotherForum.NET/default.aspx?g=posts&t=13448
big-vee-twin
posted on 9/4/16 at 04:46 PM |
You can use screwed rod
http://www.triangleltd.com
CosKev3
posted on 9/4/16 at 06:16 PM |
Threaded bar as above,if you can fit it in.tight on some cars,including my Mac1,due to it fouling on chassis.
I use two allen cap head bolts inserted from the inside out.
40inches
posted on 10/4/16 at 10:24 AM |
I used 8.8 HT threaded rod, works fine, and you can cut it to any length.
posted on 10/4/16 at 01:52 PM |
M12x200 or M12x210 is a standard bolt size easily enough available from engineering suppliers as normal HT hex bolts. Alternatively cap screws or
stainless types are also available.
MadMaxx
posted on 10/4/16 at 05:02 PM |
Thanks to all. I will try to find M12x210 and threaded bar as alternative.
posted on 10/4/16 at 07:35 PM |
I found one on a 125cc scooter, the hinge for the engine, fitted mint!
