Author: Subject: Fixing press studs
johnH20
posted on 3/5/16 at 02:51 PM Reply With Quote
Fixing press studs
I am currently fixing press studs for my tonneau cover using rivets for the male piece. In two locations I cannot get a washer on the back of the rivet ( fixing into fibre glass ). I am concerned that repeated pulling on the press stud to remove the tonneau will eventually result in the rivet pulling out. What are my options? I had thought of using M4 rivnuts but I have never managed to set one of these without stripping the thread - may be better in steel? Are there any other clever fixings that might do the job? I am restricted to head diameter of 7 mm to fit inside the male press stud. Any ideas appreciated.
40inches
posted on 3/5/16 at 03:00 PM Reply With Quote
I used a drop of SuperGlue on the threads of a small c/sk stainless self tapper. Hope I don't need to take them off
loggyboy
posted on 3/5/16 at 04:47 PM Reply With Quote
Try load spreading rivets.
Load Spreading Aluminium Pop Blind Rivets. LSR 4.8 Diameter. Choice of lengths
Mistral Motorsport
johnH20
posted on 3/5/16 at 07:27 PM Reply With Quote
Thanks loggyboy, top tip. Never heard of these before.
