New Topic New Reply
Author: Subject: Engine (stand) mounting plate
jps
posted on 5/10/16 at 01:03 PM Reply With Quote
Following on from a thread here -http://www.locostbuilders.co.uk/viewthread.php?tid=203800 i've scavanged some 40mm 3mm wall box section and am currently making my own engine stand (and if all goes well - another for a mate).
The actual plate to which the engine is bolted up is presenting some challenges. I've got some 8mm plate and will try to make something similar to this:
But I am also wondering whether I could make something to do the same job using 3mm plate (which I have ready access to) - and then strengthening it by putting bracing behind it - such as some 25mmx3mm strips welded on at 90degrees (i.e. effectively adding gussets to the rear of the face plate)...
posted on 5/10/16 at 02:00 PM Reply With Quote
How is the flat plate secured to the round section?
jps
posted on 5/10/16 at 02:20 PM Reply With Quote
In that picture (which is not my stand!) it's not connected yet.
In my stand the round section is 3mm wall round tube - approx 50mm dia - and it'll be welded onto the rear face of the mounting plate.
If the mounting plate is the 8mm I am expecting just to weld to the tube with no gusseting.
If the mounting plate is 3mm I would expect to gusset up to the tube - something like this (i'd guess at about 1inch of overlap onto the tube:
New Topic New Reply
