pekwah1
posted on 13/10/16 at 10:49 AM |
IVA Tell tale
Hi guys,
Anyone know if the fog, main bram etc tell tales are OK to be the light on the switch that operates the function or does it have to be a separate
light?
Cheers Andy
benchmark51
posted on 13/10/16 at 12:03 PM |
My rear fog (rocker) switch has a light built in. The main beam, indicator, oil, and ignition are separate lights on the dash and were ok for the
test. Yet to build in a warning lamp for my grandson swiping my toffees! lol.
adithorp
posted on 13/10/16 at 12:39 PM |
AFAIK... Tell-tale on the dash or on the switch is OK, as long as they can be seen from the driving position (reasonable movment of the
driver/wheel/controls to view is permitted). They must be clearly marked. The brake fluid level warning light must have the (correct) symbol on the
illuminated surface. The rest can be beside the switch/tell-tale.
http://jpsc.org.uk/forum/
pekwah1
posted on 13/10/16 at 12:44 PM |
cheers guys
pekwah1
posted on 13/10/16 at 12:49 PM |
Thinking about it, i know it sounds stupid, but are you allowed more than 1 telltale for each item, so maybe for main beam, the switch and an LED
would light together?
ianhurley20
posted on 13/10/16 at 02:07 PM |
With the fog light don't forget that now it must extinguish when you turn the headlamps off and not come back on without a further operation of
the on switch for IVA
907
posted on 13/10/16 at 02:16 PM |
The main beam tell tale, usually blue, goes off when you dip your headlights.
This would normally be operated by a stalk on the column, so almost impossible to have the warning light on the switch.
Therefore I would say that you must have a separate main beam tell tale on the dash and not on the switch.
The same will apply to indicators.
Side lights, and therefore dip, will normally be wired to the gauge illumination so these become the tell tale.
I think that makes sense.
Paul G
pekwah1
So does that mean if you turn on the fogs with the headlights, and then turn the headlights off, the fog light switch has to unlatch somehow?
If that's the case, how are people generally doing this?
I do have the escort switchgear which I think might satisfy that but wasn't actually planning to use it....
ianhurley20
posted on 13/10/16 at 02:24 PM |
That's right, not sure how the electrikery works but its something to do with a non latching relay, CBS sell one. I used my MX5 wiring loom and
it already did it so mine was not a problem
From the IVA manual
Rear fog lamps;
1.
They must be operational
2.
The correct number must be fitted to the vehicle (Table 1)
3.
They must only emit a red light
4.
The rear fog lamp(s) must only illuminate when dipped beam, main beam or front fog lamps are lit (See Notes 3 & 4)
5.
They must be positioned correctly to meet
a.
the positional requirements of Table 1
b.
the angles of visibility requirements of Table 1
6.
Must be fitted with an operational “tell-tale” lamp (non-flashing) visible from the driving position
7.
Either the switch or tell tale must clearly indicate that operation relates to the Rear Fog lights (see Note 1).
8.
Must not be operated by a brake control
9.
Fitted so that the reflector is facing squarely to the rear
10.
An optional rear fog lamp must form a matched pair with the obligatory lamp
11. An optional rear fog lamp must only operate with the obligatory rear fog lamp
12.
All rear fog lamps must display an “e” or “E” mark with a “B” or “F” (see note 2)
[Edited on 13/10/16 by ianhurley20]
Note 3: front fog lamps may be illuminated with the side lamps only.
Note 4: Either of the following applies:
1) The rear fog lamp(s) may continue to operate until the position lamps are switched off, and the rear fog lamp(s) must then remain off until
deliberately switched on again or,
2) An audible warning, additional to the mandatory tell-tale light, must be activated if the ignition is switched off or the ignition key is withdrawn
and the driver's door is opened, whether the lamps in (RS4) are on or off, whilst the rear fog lamp switch is in the "on"
position.
tims31
posted on 13/10/16 at 06:26 PM |
I thought that this had been removed but looks like its been reinstated again. Mine only come on with the Main/dip beam and the use of a switch.
Anyone have a wiring diagram of how to make it only come on when pressed again, will also need to be able to switch it off without having to switch
all the lights off again.
Build: http://www.martinsfurybuild.co.uk/
avagolen
posted on 13/10/16 at 06:31 PM |
Rear fog switching logic. Mmmmm,
When I passed my IVA a year last April, the rules were in place but as mine was wired up with the 'Sierra' wiring no questions were asked
and it passed with no comment.
I think a call to the test centre would answer any questions about whether it was absolutely required for our vehicles.
I think the suppliers are jumping on the 'you must have this' bandwagon and raising the price of 'locost' building.
As our cars are using old fashioned ignition and light control switches, I think they fall into the old rules.
Just my understanding of the rules, might be wrong though in a big way.
Badger_McLetcher
posted on 13/10/16 at 06:38 PM |
I think it comes down to how you read this line:
4. The rear fog lamp(s) must only illuminate when dipped beam, main beam or front fog lamps are lit (see alternatives in Notes 3 and 4).
The way I read it was that the alternatives in notes 3 and 4 are for if the rear fogs will illuminate on your side lights only.
Note 4: Either of the following scenarios will also be considered acceptable:
- The rear fog lamp(s) may continue to operate until the position lamps are switched off, and the rear fog lamp(s) must then remain off until
- An audible warning, additional to the mandatory telltale light, must be activated if the ignition is switched off or the ignition key is withdrawn
position.
So to clarify, my interpretation is that if you've wired it so they only come on on dipped or main beam you can get away with a normal latching
switch and tell tale.
[Edited on 13/10/16 by Badger_McLetcher]
If disfunction is a function, then I must be some kind of genius.
pekwah1
posted on 13/10/16 at 08:18 PM |
Well not exactly, it means that the fog light must not come back on when turning on dipped beam, otherwise you need a buzzer or similar if you leave
the fogs on and turn off the ignition.
Anyone know how to wire up a buzzer on ignition off?
ianhurley20
posted on 13/10/16 at 08:25 PM |
My car passed IVA on 3rd October this year and the fog light operation was tested, headlights on, fog on, now turn off your heads etc, thankfully I
had seen another IVA a few weeks before and was ready for the procedure
WesBrooks
posted on 14/10/16 at 07:43 AM |
Double pole switch for the fogs. Use one side of the switch to drive the fogs or fog relays as usual. Connect a small change over relay coil to the
key switch ignition. Feed a fused permanent live to the common relay contact and pass the normally closed side to a buzzer so that it will sound until
the coil is energised. pass the ground side of the buzzer to the switch, then ground it on the other side of the switch possibly through the door
switch if you have them.
Circuit:
A) Ignition Live -> Change over relay coil -> Ground
B) Battery -> Fuse -> Changeover relay (common & normally closed) -> Buzzer -> spare pole on fog light switch (-> Door open switch
)-> Ground
Basic logic for the buzzer to sound would be:
Ignition off + fog light switch on (optional: + door open)
If you already have a ignition relay then you could consider swapping this out for a change over relay. If doing this I'd consider adding an
in-line fuse after the relay as you shouldn't need any more than 1A and this will allow you to save on wiring weight/cost on the buzzer
circuit.
This is what I was considering doing. I can't see any reason why it wouldn't be permissible to share this buzzer with head lights on
warning etc.
I prefer the warning buzzer route as there are occasions where you may wish to switch of ignition and restart in a hurry, for example if you stall.
This way the car would buzz at you while you restart, but the fogs would come back on immediately. This would get my rear fogs back as soon as
possible if I did stall on a foggy twisty rural road without me having to re-trigger them, or possibly forgetting to restart them after the
fuss/surprise/stress of a stall.
[Edited on 14/10/16 by WesBrooks]
http://doctrucker.wordpress.com
pekwah1
posted on 14/10/16 at 08:14 AM |
Thanks for this, i will need to digest a bit more i think, but sounds similar to another solution i've found which is to use a 5 pin relay and
use the normally closed side for the buzzer.
Maybe that's basically the same as you've just suggested, but i'm not clever enough to know that
WesBrooks
posted on 14/10/16 at 08:24 AM |
No problem, could well be the same! A five pin relay would be what I meant by a change over relay. If your solution is different please share it.
I'm planning my loom at the moment and interested in simple rugged solutions!
pekwah1
posted on 14/10/16 at 09:16 AM |
i took a screenshot of a diagram on my ipad, i'll post it up when i get back home!
pekwah1
posted on 14/10/16 at 07:05 PM |
This is what I found...
