pekwah1
posted on 8/1/18 at 09:40 PM |
Inlet manifold
Hi guys,
Just after some advice, I have a stock 2.0 blacktop zetec running on standard ecu.
It’s using the stock inlet manifold and throttle body, but I also have a log type inlet manifold sat in the garage that I haven’t got round to fitting
yet.
Now this will give me some clearance benefits under the bonnet, but just wondering if it gives any real benefit over the standard manifold?
I also have a slightly larger throttle body that I could fit, but don’t know whether I can just fit this or whether I’d need to consider larger
injectors at the same time?
Any advice appreciated, I’m clearly not to clever with this stuff
big_wasa
posted on 9/1/18 at 11:51 AM |
The log manifold is often used for packaging reasons rather than optimum air flow. Putting a bigger throttle body on it is likely to just make it
harder to drive at part throttle, smaller movements of the pedal allow more air in. The throttle will be more on/of. You may get a bit more induction
noise but the Tb is not the limiting factor so it won't make more power.
A better designed plenum will give a little more gain but only if the exhaust has been freed up. But your still limited by the Maf and oem mapping.
Even with a stand alone ecu you won't need bigger injectors with out making the engine flow more with cams and head work or a turbo.
pekwah1
posted on 9/1/18 at 01:06 PM |
Nice one thanks, kind of as I expected.
The manifold will help me for packaging as you mentioned so will probably do that in time and ignore the TB
big_wasa
posted on 9/1/18 at 05:45 PM |
Being nosey, What sort of log manifold have you got ?
pekwah1
posted on 9/1/18 at 07:25 PM |
Honestly I can’t remember, I bought it from someone on here but haven’t fitted yet
I’ll have a check next time I’m in the garage
