johnH20
posted on 20/5/18 at 11:01 AM |
Bars Leaks
I have discovered my radiator has a minor leak, barely visible. I know this will mean a replacement rad at some time but I would rather put that off
till the winter. In the 'old days' there was something called Bars Leaks that I remember using on an old Ford Anglia. Does this still
exist and more importantly will it compromise the rest of my cooling system in any way?
johnH20
posted on 20/5/18 at 11:11 AM |
Sort of answered my own question ( Google is your friend ). Yes it is available but some horror videos on Utube so I will not be using it. BE WARNED!
steve m
posted on 20/5/18 at 03:56 PM |
Pour a raw egg in the filler does exactly the same thing
steve
![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
russbost
posted on 20/5/18 at 04:23 PM |
John
Use K seal, it's not destructive in terms of blocking waterways etc. like Bars is, & has an excellent reputation - the AA carry it as a
roadside repair I believe!
Russ
johnH20
posted on 20/5/18 at 06:09 PM |
Thanks Russ. I will give K Seal a try. By the way are you reading LB in Vietnam or are you back from your hols?
ian locostzx9rc2
posted on 20/5/18 at 06:22 PM |
Plus one for k seal
russbost
posted on 20/5/18 at 06:54 PM |
I'm back!
907
posted on 21/5/18 at 06:08 AM |
I wouldn't use any of those snake oils. We'll be cracking eggs into brake fluid reservoirs next.
I've just bought a rad for an MX5. £49 inc p&p. Why mess about?
Angel Acevedo
posted on 21/5/18 at 07:26 PM |
Where´s the leak...
In the old days you would strip a tube of its cooling fins and cut the tube near the leak (or at the leak) and fold it a couple of times with a needle
nose plier.
Don´t know if it works with ali rads.
HTH
Schrodinger
posted on 22/5/18 at 08:35 AM |
I'm not sure where you are but http://www.sheldrakeandwells.co.uk/
in ipswich have repaired and modified rads for me in the past.
Keith
Aviemore
SPYDER
posted on 22/5/18 at 09:06 AM |
steve
Soon to feature in Heston Blumenthal's new book, " Roadside Cooking".
Page 7.
"Eggs a la Locost"
Cost to make, £250 of course!
