number-1
| posted on 11/6/18 at 09:51 AM |
twin axle caravan trailer weight?
Does anyone have a home made twin axle caravan chassis trailer? Im curious to know the rough weight of one as they look pretty light. I know there are
probably loads of variants, but just trying to get a rough idea to see if its something i should be looking at to tow a 380kg kit car but more
importantly, manouver it into a single garage by hand with the car on it!
N1
rf900rush
| posted on 11/6/18 at 10:40 AM |
Just finished converting on to carry a Glastron GT150 speed boat with a 90hp engine. The trailer does not feel that it is loaded enough.
Our last caravan (now stolen) was a Swift twin axle and it's total weight was nearly 1.8 tones.
miskit
| posted on 11/6/18 at 11:24 AM |
I used one to move the Fug. - Very light and was the only way to get car+trailer below the towing limit of my car. All the "proper" car
trailers I looked at were 700kg. This one was around 200kg, single axle braked.
Sold it after the move.
[Edited on 11/6/18 by miskit]
907
| posted on 11/6/18 at 12:07 PM |
I bought an Alko chassis and made the top myself. I did make another for a mate.
The axles are 1100kg each and I've plated the total as 2000kg as my car will pull 2100kg, so it can carry 1500kg ish.
With ramps, winch, and all, it came in at 450kg.
The idea was to have a drive on trailer that was no wider than the tow car.
Paul G
  Transport wheels only
number-1
| posted on 11/6/18 at 08:37 PM |
Cheers for the replies chaps
Paul G, those trailers like pretty smart! Do you remember the overall length? It looks like what i need
907
| posted on 12/6/18 at 07:41 AM |
The load area is 1830mm wide x 3100mm long. Total length is 4620mm.
The whole chassis is modular and I could have bought several different lengths and widths to mix and match.
The "A" drawbar could be cut and re-drilled to reduce the overall length. Wheels are 195 / 55 / 10.
A twin axle caravan will be longer but easy to cut down and re-drill. Just need to get the wheels in the right place.
Heres a pic with a car on, my sons track MX5, to give a better idea of size.
Paul G
  Gaz's track car
