ibakes
posted on 6/4/19 at 07:38 PM |
Megasquirt rpm issue
Hi all. Having a bit of an issue
I have a ms1 v3 eck running ford edis 4 ignition.
My car has been off the road for a number of years and have rebuilt it and ready to get it running again.
Before I took it off the road it was running but had a very bad map.
The other day I started the car up for the first time since the rebuild and it was running quite happily. The temperature came up, fans cut in and it
was idling nicely while I was keeping an eye on tuner studio.
Anyway after 20/30 minutes of it running, it suddenly stopped and I'm still having issues to get it started again.
I have figured out today that when in tuner studio I have no rpm showing when I am cranking it over. But I do have rpm on the simulator
When I turn the car on I get the initial prime of the injector and then no more fuel when cranking.
I get very random sparks from the plugs
I have 12v on the middle pin of a new coil paco. And get around 4mv on the vr sensor when cranking. I am still yet to buzz out the other 2 leads to
the coil pack.
Is there a way I can test the edis module just with a multimeter for the saw and pip signals?
Otherwise I will be buying a new one from eBay
Thanks in advance.
scimjim
posted on 6/4/19 at 08:20 PM |
Symptoms sound like crank sensor - is 4mv enough? Will an Edis fault stop fuel/injectors?
ibakes
posted on 6/4/19 at 08:30 PM |
It will stop fuel as the ms does not know the engine is turning. Pretty sure that's right anyway.
Will see what I can find for the vr sensor voltage
Its just annoying how it was running really nice and started and stopped with no issues.
G13BLocost
posted on 6/4/19 at 09:06 PM |
I had literally the same setup and had ignition noise issues. Are you running low or high impedance injectors?
My Locost blog: ogilvietacing.com
ibakes
posted on 6/4/19 at 09:11 PM |
Standard duratec injectors. Not sure if they are high or low.
It's been working before and was ok for a good 30 mins before it stopped.
Also I think I read my voltages wrong. It read 4 on the .200 setting so .4 of a volt
scimjim
posted on 6/4/19 at 09:17 PM |
You’re right - MS needs the PIP signal from the EDIS to know the engine’s turning. I’m just learning all of this having fitted a zetec on MS which
seems to have dead injection drivers!
And VR voltage when cranking is only mV.
[Edited on 6/4/19 by scimjim]
scimjim
posted on 6/4/19 at 09:22 PM |
TPS hasn’t died has it - if MS thinks it’s wide open it will go to flood clear mode (ie no fuel)?
ibakes
Thank you. Glad I'm on the right lines.
Just annoying at the moment as I would rather be working on a decent map (ok letting tuner studio do it)
Might replace the vr sensor then the whole lot would have been changed.
It would be good to confirm what the issue is
ibakes
posted on 6/4/19 at 09:24 PM |
No tps is still fine and you can see floid clear active when fully open.
big-vee-twin
posted on 6/4/19 at 09:53 PM |
I would get rid of the EDIS and use the MS to control sparks
http://www.triangleltd.com
obfripper
posted on 7/4/19 at 10:24 AM |
Set your multimeter on ac 20v range, the vr sensor should show approx 3v while cranking.
If your dvm has a frequency setting, the output should be 180hz at 300 rpm.
Check the resistance of the sensor, it should be 400ohms, recheck it at the edis connector end, it should be the same.
I have also had several zetec se crank sensor mounts work loose and the sensor touch the flywheel, this can break the internal magnet and reduce/stop
output voltage.
The edis unit is normally bulletproof, i have never replaced one for a fault.
Dave
posted on 8/4/19 at 10:54 AM |
This! If you are getting only 4mV on the AC voltage setting then the sensor is dead, it should be at least a couple of volts at normal cranking
speeds.
ibakes
posted on 10/4/19 at 08:24 PM |
Hi All
you were correct a new sensor and it started straight away, thanks all.
Now on to the map. I will upgrade to the full version of tuner studio and use this for the moment ![](/images//smilies/smile.gif)
