ADH75
posted on 26/12/20 at 04:24 PM |
New member
Hi, thought I'd pop in and say hello as a new member of the forum, . Wanted to build my own for many a year but never had the time or space to
do so, so I've just bought myself a built car.
Now the owner of a Formula 27 with a 2.0 pinto engine that's not long had a 4 figure rebuild. Hopefully be giving it a bit of a spruce up before
heading out for a few good runs in the summer. Basically a wee project and bit of fun for myself and my 11 year old son.
Not from a mechanical background so be gentle and apologies for all my stupid questions in advance! 😁
Andrew
[Edited on 26/12/20 by ADH75]
posted on 26/12/20 at 05:25 PM |
Welcome , just take it easy when you first drive it, these cars can BITE especially in damp conditions
jacko
posted on 26/12/20 at 05:32 PM |
Welcome to the mad house and as rusty says go steady and mine wet leaves on the road
Jacko
ADH75
posted on 26/12/20 at 06:16 PM |
Cheers, my first drive in anger was on wet roads, an experience and a half. It was delivered to my work, where I had to drive to another work site
where they were letting me store it (long story as to why, but didn't tell the other half I'd bought it!! She is aware now though).
Noticed I kept locking the front wheels when stopping, so had to slow down well back just incase. Also had to negotiate a very busy roundabout that is
a nightmare at the best of times, but now know it really can shift off the line all be it with a bit of a wiggle.
Just need to treat it with respect, and learn it's foibles. I think the thing that will take longest to get used to will be being very aware of
your own mortality. I always knew you were low and exposed, but you don't appreciate how low and exposed until some HGV pulls alongside side
you.
First lesson though is how to get in and out of it with slightly more grace than that of a drunken elephant!
perksy
posted on 26/12/20 at 09:16 PM |
Welcome
Take it easy until you get used to it and if you get chance check the front wishbones for cracking
I know of one or two that have let-go on F27's and I was behind a lad on a club run once where his driver side failed, luckily we had just
pulled up to a junction when it failed (10 mins earlier and I'm not sure he'd still be with us)
ADH75
posted on 26/12/20 at 11:58 PM |
Thanks for the tip. I'll get them checked when I next nip up and check on the car. It's not been bought as a track car or fast road car,
but that's good to know about as most trips will be wee road trips with the young lad & the last thing you want to do is put him at any
risk.
I did try and find out as I could, but unlike other models I didn't find too much on the F27. I take it the wishbones is the only real area of
the car to keep a closer eye on than your regular maintenance?
posted on 27/12/20 at 07:49 AM |
I suspect a lot of wishbone failures were due to the well known crush tube issue. Basically the crush tubes are too short resulting in the wishbone
not pivoting correctly when the mounting bolts are tightened, I have, in fact, seen a build manual stating the bolts should not be tight! I don’t know
if this applies to the f27 ?
Dingz
posted on 29/12/20 at 07:04 PM |
You probably know but tyre pressures are much lower than a tin top, more like 18psi. Otherwise you’ll be skating everywhere.
went on and on.
snapper
posted on 30/12/20 at 03:43 PM |
How to get in to a Lotus Seven at 5mins in.
Me being 5’8” it’s to much of a bother, the guy in the video is 6’ by the looks of it.
https://youtu.be/GhroAb24uQs
[Edited on 30/12/20 by snapper]
I eat to survive
I drink to forget
