| posted on 11/3/05 at 09:18 AM |
Crud in the header tank
I've an Astra header tank that I intend to fit to my car over the next week or so. It was filthy when I got it, so I gave it the usual bath in
Arial, which got most of the grot off.
Trouble is, there's a brownish coating inside that won't shift - the Arial didn't get it, I've tried descaler, citric acid and
Calgon. I haven't got a dishwasher, so that option's out.
Anyone suggest anything else? I don't want to despoil my nice clean engine bay with a grotty header tank!
Surrey Dave
| posted on 11/3/05 at 09:22 AM |
I tried all sorts of chemicals on mine , in the end I pushed a piece of cloth in and pushed it around with a screwdriver or something.
Worked quite well.
Deckman001
| posted on 11/3/05 at 09:32 AM |
Yep, same as dave but with a bit of ariel in it as well
Jason
Snuggs
| posted on 11/3/05 at 09:39 AM |
Try using some dry course sand and give it a really good shake.
Clive
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
wicket
| posted on 11/3/05 at 09:41 AM |
Hot water and vinegar, let it stand for a while, added a table spoon of brown rice and gave it a damn good shaking.
It did need the cloth and screwdriver treatment in the corners, here's what it looks like now
James
| posted on 11/3/05 at 09:50 AM |
I didn't even get as advanced as cloth and screwdriver. I used a..... stick!
I tell you, it's like a Formula 1 workshop in my garage at times!
James
- Muhammad Ali
Surrey Dave
Sounds like a Locost lunch!!
DaveFJ
| posted on 11/3/05 at 10:43 AM |
Is that an Astra header tank in Wicket's piccy ?
looks like a good solution to yet another problem i didn't realise I had!
Dave
| posted on 11/3/05 at 10:49 AM |
awful like a Rover 214 header tank ?
| posted on 11/3/05 at 10:51 AM |
Rover 200/400 range.
I have one of these - it's "Plan B" if I can't get the Astra tank to fit where I want...
The long legs are a pain to fit - they're too long for fitting in front of my scuttle firewall - but they're easily cut if necessary.
| posted on 11/3/05 at 10:52 AM |
Sounds like a case for Cilit Bang !!!!!!!!!
Try a solution of either phosphoric acid (pink rust remover) or borasic acid (boiled up Rhubarb leaves)
locoboy
| posted on 11/3/05 at 11:39 AM |
seem to remember someone putting clean gravel in there with washing powder and giving it a good shaking.
might be worth a go.
Rover SD1 header tank is a nice size too.
Locoboy
mangogrooveworkshop
| posted on 11/3/05 at 12:39 PM |
Some have used the dishwasher............mmmmmm at your own risk of having swimbo banish you from the house.
| posted on 11/3/05 at 12:41 PM |
Tricky... haven't got one!
Donners90
| posted on 11/3/05 at 01:22 PM |
Neat bleach works a treat
Put a small amount in the tank then seal the holes. rotate it every 15mins and rinse out! :-)
MikeR
| posted on 11/3/05 at 04:01 PM |
for how long?
(really wanted to write at what speed but you've told us 4rph - revs per hour)
| posted on 11/3/05 at 05:20 PM |
quote: Originally posted by britishtrident
Sounds like a case for Clit Bang !!!!!!!!!
At my first reading I wondered... what the hell? My "our lass" wince....
| posted on 11/3/05 at 05:25 PM |
Dish washer powder might also be a good bet it as been tested for cleaning mains water tanks and proved better than the specialist chemical the water
companies were using.
| posted on 11/3/05 at 06:40 PM |
Have used dishwasher powder with good results in the past, also dry sand .Rhubarb leaves sound interesting but where do you get then in the middle of
winter?
Mark Allanson
| posted on 11/3/05 at 08:25 PM |
Like I said yesterday, boracic acid comes from volcanoes, oxalic acid comes from rhubarb!!
Alan B
| posted on 11/3/05 at 08:53 PM |
SWMBO or dishwasher?
Or is that the same thing?
(runs for cover.........)
stephen_gusterson
| posted on 11/3/05 at 11:19 PM |
if you ever put barrs leaks or radweld in the system, it will end up back at that colour anyway!
atb
steve
| posted on 11/3/05 at 11:40 PM |
winter?
The seasons just started -- only forced Rhubarb so far but in a month or so.
| posted on 11/3/05 at 11:42 PM |
I was wondering why I had heart burn :-)
| posted on 12/3/05 at 12:09 PM |
Well, a stick and bits of EBG* got rid of nearly all of it, and now it's back in some Arial washing powder for 24 hours or so. Looking a lot
better!
cheers,
* EBG = Elephant's Bog Roll (a.k.a. blue workshop paper towels)
