MK9R
| posted on 20/11/02 at 07:59 AM |
DAX SVA Bumper
I know this was discussed a few weeks ago, but i thought some of you may be interested in what i found out at exeter.
The bar that protrudes out infront with the front suspension on the DAX Rush is indead fro SVA. It means that nothing on the front suspension will be
tested for SVA, i'e no nut covers, gators, lagging is required. Also, if you fit the side lights to this bar it means that you can sit the head lights
a lot lower, as the side lights need to be visible from the side, but not the headlights. It is also a good place to put your indicators. On the DAX
the bar is fitted to the 2 upper wisbone pivots/bolts and is therefore very easy to remove (without ruining body work etc), if you wanted to??!!
The bar inside the nose cone is also for SVA, but apparently they don't bother to be checking it.
See picture below
RoadkillUK
| posted on 20/11/02 at 01:47 PM |
So what you are saying is that if anyone fits a bar similar to the one in the pic, then the radius of the suspension bolts/nuts and steering will be
exempt from the SVA?
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
philgregson
| posted on 20/11/02 at 04:08 PM |
This is too good to be true!
If it works it has to be the way forward!
Can anyone give me any good reasons not to?
(go on I know you can)
Phil
MK9R
| posted on 21/11/02 at 12:35 PM |
Quote "So what you are saying is that if anyone fits a bar similar to the one in the pic, then the radius of the suspension bolts/nuts and
steering will be exempt from the SVA?"
Thats right!!!
And i have always loved the look of the front of the DAX with the low, square headlamps!
