Nick Davison
posted on 1/6/05 at 11:04 AM |
What if the inspector can't see stuff
If the SVA inspector can't see some specific and vital inspection points because of no access etc what can/will he want me to do. Mainly seat
belt mounts (because of carpets and seats) and brake bias bar (because of covering pannels and additional components mounted on top)?
Nick
flak monkey
posted on 1/6/05 at 11:06 AM |
Its usually worth taking some good clear photos of those bits that are hidden, so if he/she queries then you can show them something.
AFAIK they are allowed to ask you to remove certain bits of the car, but not sure what that stops at. I think its only trim, nothing major.
Sera
http://www.motosera.com
posted on 1/6/05 at 11:33 AM |
Basically - the SVA man is not stupid. If the quality of the car is consistantly good he is less inclined to go digging! If your build is a bit
suspect he will investigate further...
At the end of the day - he is there to protect you and to maintain a high standard of safety. If you (god forbid) total it on the way out he is going
to be responsible in some way, so he has to protect himself too.
HTH
posted on 1/6/05 at 11:51 AM |
The SVA man invited me to look at something under the car when it was up on the hoist - you can see a hell of a lot from down there!
I believe that he can ask you to lift or open any part that's not permanently fixed (inspection covers, loose carpets, etc.).
Taking pictures is a good idea, but make sure that they are an honest view - don't look as though you're trying to hide something! Take a
few different views of each item, just to be sure.
cheers,
Fozzie
posted on 1/6/05 at 11:58 AM |
Mine asked me if I would remove one seat, of which I was happy to oblige!
The lower seat belt mountings could be seen, but he wanted to make sure that it was as safe as it looked!
As said before, its only your safety (and other road users) that they are concerned about!
Fozzie
DarrenW
posted on 1/6/05 at 12:10 PM |
My father failed first time and was told to make the seat belt mountings and under tunnel area available for inspection on the re-test.
A good tip i was given was to take a photo album, theres a good chance these will suffice.
Nick Davison
posted on 1/6/05 at 12:29 PM |
Thanks guys it looks like loads of photos then.
Interesting about the seat belt anchorage Darren and Fozzie, that is one of the main areas I was concerned about as they will have carpet and close
fitting seats covering them. The last thing I want is to have to strip the car down again for the retest, it isn't the most straightforward
build.
Many thanks
Nick
