ady8077
| posted on 4/6/05 at 09:28 PM |
help sheared bolt
Hi
one of the bolts on my second hand vw fuel swirl pot snapped, the tanks plastic and trying to turn it with pliers has just rounded it off
Any ideas?
| posted on 4/6/05 at 09:36 PM |
Arent they captive anyway? If they aren't it is now...
ady8077
| posted on 4/6/05 at 09:40 PM |
Hi
The other 2 were like a big self tapper, all 3 heads were rusty, but this one wont budge
Adrian
jambojeef
| posted on 4/6/05 at 09:53 PM |
Is that a bit of the bolt sticking upwards or do the bolts project into the tank?
Cant quite picture it - even though theres a picture - if you know what i mean!
Geoff
ady8077
| posted on 4/6/05 at 10:01 PM |
Hi Geoff
Thats the bolt after the head snapped off
Theres about an inch of bolt that still needs to come out
Adrian
shades
| posted on 4/6/05 at 10:48 PM |
How about heating the end of the bolt with a soldering iron and trying to pull it out?
big_wasa
| posted on 4/6/05 at 10:58 PM |
drill it and heli coil it.....I swear by them..
ady8077
| posted on 5/6/05 at 08:23 AM |
Tried heating it with soldering iron, but mines quite low powered and it didn't get it very hot
how do i drill a steel bolt out of a plastic tank?
Adrian
| posted on 5/6/05 at 09:56 AM |
Grind the top flat, support it from underneath and centrepunch it. Then start with progressively larger bits till you get to the thread and you may
then be able to peel it out with snipe nose pliers or tap what's left out. The heat from drilling may work it loose if you're lucky.
ady8077
| posted on 5/6/05 at 11:12 AM |
Hi Pete
Because the bolts a self tapper, its shank is only 3mm thick, wish i'd left the rust bolts in now
Adrian
paulf
| posted on 5/6/05 at 06:49 PM |
Cant help on how to get the bolt out , but is that a small seperate fuel swirl tank ? what VW did it come from ?
Paul.
ady8077
| posted on 5/6/05 at 07:05 PM |
Hi Paul
Yep seperate swirl pot with built in high pressure fuel pump
Got it off ebay, its off a Mk2 golf GTI
Adrian
Liam
| posted on 5/6/05 at 11:26 PM |
Oooooh - could you give some rough dimensions for it?
liam
um... good luck with the bolt
paulf
| posted on 6/6/05 at 10:14 AM |
That sounds usefull as i am planning a megasquirt conversion during the winter, Ill keep my eyes open for one.Just have to decide what engine to use ,
i have a crossflow fitted and a blade engine that I was going to fit, but am tempted by a 160 +hp zetec which should be easy to achieve .
Paul.
quote: Originally posted by ady8077
Hi Paul
Adrian
paulf
| posted on 6/6/05 at 10:16 AM |
How about filling the tank with boiling water? and then a good pair of molegrips on the bolt.
Paul
Adrian
ady8077
| posted on 6/6/05 at 04:58 PM |
Thanks for the tips on the bolt, still stuck though
For those interested in the golf fuel pump, theres a few on ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=9889&item=4554400869&rd=1&ssPageName=WDVW
I havn't been able to find specs on the pumps flow and pressure ratings, but i'm hoping it will work ok on a 150bhp pinto
Adrian
DarrenW
| posted on 7/6/05 at 09:24 AM |
It should work no problem. The std mechanical fuel pump is supposed to be almost man enough for 150bhp so high pressure pump should be good.
You may need to think about a fuel pressure regulator. I got one for £25ish with adjustable dial (im running 38DGAS and had facet red top in stock so
will be regulating it down quite a bit - plenty in reserve for future upgrades.)
