paul v6
posted on 20/9/05 at 05:11 PM |
Kangoo Diesel
My 1.9 diesel Kangoo has developed a problem
It seems to have air in the fuel lines but I've not ran it out of deisel? This causes the engine to run eratically and cuts out on occassion,
usually at the most inconvenient times!!
Does anyone has any idea how to bleed one of these engines????
Paul
posted on 20/9/05 at 05:26 PM |
Sounds more like fuel filter problems. If it needs bleeding it won't run.
gary gsx
You wont get air in the system if you haven't run out of fuel and not disturbed anything, Sounds more like a dirty filter have you had a new one
fitted lately?
Could be drawing air in through a loose pipe,faulty washers on a banjo fitting, seal fault on filter
Just a few ideas Gary ![](/images//smilies/cool.gif)
colibriman
posted on 20/9/05 at 05:28 PM |
deffo go for fuel filter...may have water in it...happened to my xantia and it ran like poo
need a bike engine? - www.colibriman.com
SVA ready Mk Indyblade possibly for sale.....if the offers good...!
donut
posted on 20/9/05 at 05:31 PM |
Colin,
poo can't run!
Just thought i would point that out! ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Guinness
posted on 20/9/05 at 05:37 PM |
I dunno Andy, I've had some pretty bad curries that've had that effect.
Mike
colibriman
posted on 20/9/05 at 05:38 PM |
john_p_b
posted on 20/9/05 at 05:45 PM |
Paul
what year kangoo is it? i spend 5 days a week maintaining a fleet of these at work.
pre 2000 models have a very common problem with a little valve on the fuel pump faulting, usual simptoms are a rocking motion when stationary at idle,
an apparent missfire when accelerating which often clears when you get the revs up and at times they just plain cut out!
you'll always see air in the fuel lines, god knows how the run like it i've never seen a oil burner have as much air in the fuel lines as
these do!
built a car, built a home, had a family. lost the family, lost the home, still got the car.
paul v6
posted on 20/9/05 at 09:21 PM |
Hi John,
The problems you descibe are absolutely spot on, but its a 15 plate so post 2000??
Any ideas??
Paul
